Forum Topic - Cron use file update re PR65361: (3 Items)
I was digging through the sources trying to debug some issues we were having with cron on 6.3.2 (likely the result of
our automatic system time synchronization) and I was very pleased to find that you'd beaten me to the punch in putting
in a poll mode. Thanks! :)
I did notice that the use file wasn't updated with the new -s option, though.  Is this something that's normally handled
 separately through a documentation PR, or is it the responsibility of a developer issuing a patch to update the docs
with the source files?
Curious,
-Will
Re: Cron use file update re PR65361
Will Miles wrote:
handled separately through a documentation PR, or is it the responsibility of a developer issuing a patch to update the
docs with the source files?
The use message should have been updated by the developer and the PR
should have been cloned for the tech writers to update the documentation.
Ryan Mansfield
> Regards,
> Ryan Mansfield
Hi Ryan,
Thanks for your reply!  If I spot any others I'll make sure to pass a note along, then.  I just wanted to be sure it
wasn't something taken care of elsewhere as part of your development process.   At least I've got the sources to look at
 now - no more disassembling the binaries to find the getopts() arguments. :)
Thanks again,
-Will
