Forum Topic - Set global environment variable using Setenv/putenv: (7 Items)
Hi All,
I tried modifying PATH environment variable using Setenv/putenv but when i exit from the application the values are not
reflected in the global environment variables. I have a requirement where the global environment variables need to
updated and should be reflected in the parent shell.
Re: Set global environment variable using Setenv/putenv
On Mon, Feb 16, 2009 at 09:02:30AM -0500, sathish kumar wrote:
> Hi All,
not reflected in the global environment variables. I have a requirement where the global environment variables need to
Changing your environment doesn't affect your parent (the
environment is inherited).  You'd have devise a scheme
whereby the parent would listen for requests to alter its
own environment.
Hi.
HOw is it possible to do any modification in the Korne shell (ksh) to reflect the environment variable changes made in
the child process. In our case the parent in the korne shell (ksh) from where the executables are invoked.
RE: Set global environment variable using Setenv/putenv
For existing children it`s not possible.  For new children you do an "export VARIABLE=..."
> From: sathish kumar [mailto:community-noreply@qnx.com]
> Sent: February-16-09 11:20 PM
> To: ostech-core_os
> Subject: Re: Set global environment variable using Setenv/putenv
> Hi.
> reflect the environment variable changes made in the child process. In
> are invoked.
> Thanks,
> http://community.qnx.com/sf/go/post22326
Process environment is data which is local to the process. Every process has its *very own* environment, like every
process has its own, private memory area[s].
Parents can not modify their childrens' environments, they can just pass an environment when the child is created;
children can not modify their parents' envirnoments.
In short: No process can modify any other existing process'es environment.
You will need to find a different approach.
What are you trying to do?
I am trying to return a value from a executable file and use the returned value in Korne shell script. As my return
values are restricted to 8 bit when i access $? in shell script, i try loading a environment variable in my executable
and use the environment variable in the shell script to know the return values of my executable.
For example
#./a.out
#echo $PROG_OUTPUT
Where a.out loads the PROG_OUTPUT with the return value to be used in the shell script.
> Sent: February-17-09 10:39 AM
> To: ostech-core_os
> returned value in Korne shell script. As my return values are
> environment variable in my executable and use the environment variable
Have your process "print" the value. And then in the shell do
PROG_OUTPUT=`./a.out`
echo $PROG_OUTPUT
> For example
> #./a.out
> #echo $PROG_OUTPUT
> the shell script.
> Thanks
> http://community.qnx.com/sf/go/post22351
