Forum Topic - Cyclic timer trouble ?: (3 Items)
Hi, I've a problem with cyclic timer:
In an application running on a Pc-like QNX6.2, x86 system, 100us
system clock, one process create a 150ms cyclic timer (with a
priority of 30).
In this application (not under our control) the client thread stops
to receive the timer pulses, so they will be enqueued but not
delivered to any one.
Another process has a 3ms cyclic timer, with a priority of 190.
After 5/7 days, we observe a delay in the service of one of the
the 3ms timer thread pulses: this delay has the same period of
the 150ms cyclic timer and increase every day more and more...
after 10 day it is greater than 1ms, so we have a latency of
this time in the high priority thread, that is not acceptable.
The question is: may the pulses generated by timer and not
delivered be the cause this delay ? Apperently yes...
Just to test, I've write a program that create a cyclic timer
(1ms, priority 30) and do not make any MsgReceive, so pulses are
not delivered to anyone.... And just after a few minutes the
high priority process will hung-up because its timeline
is out of boudary. After the kill of test application, all
works fine again...
It's not clear why a undelivered pulse may overload the system
in such mode...
It seems that pulses are buffered unlimited or untill memory
will be exausted.
It is possibile to limits the max number of pulses that can be
buffered ?
Thank You all
Mario
Re: Cyclic timer trouble ?
You neglect to mention the version of the OS, but yes, undelivered pulses
were an issue pre 6.4.0
Fortunately this has been fixed in 6.4.0 - however they are still and
issue since they are a kernel memory leak.  Your design should do everything
it can to avoid having a large buildup of queued pulses.
Colin
> priority of 30).
> works fine again...
> in such mode...
> will be exausted.
> buffered ?
> Thank You all
> Mario
> http://community.qnx.com/sf/go/post21044
cburgess@qnx.com
QNX6.2.x :-)
 but I've tested same appl also on OS 6.3.2 with same results.
Yes, unfortunatly, this bug is in an application not under our
controls, I've no access to source code... so I cannot do nothing
to fix this problem ...
Thank You ,
Mario
