Forum Topic - Ajax issue, problems with the responseXML from an XMLHttpRequest: (10 Items)
Has anybody attempted to use the responseXML variable from XMLHttpRequest?
I am successfully using slinger and cgi to return ajax data with the XMLHttpRequest object.  However I can not seem to
get the responseXML to parse through my xml stream?
I believe it has something to do with the browser not interpreting the header type "Content-Type: text/xml".
I am close to abandoning the responseXML variable and parsing the xml stream returned in the response variable manually.
Hopefully somebody else out there has dealt with this.
Thanks.
Re: Ajax issue, problems with the responseXML from an XMLHttpRequest
I had that issue also.  Windows flashplayer does not require anything before the xml document but qnx flashplayer does!
I send...
"HTTP/1.1 200 OK Server: custom-cgi Connection: close \r\nContent-Type: text/html\r\n\r\n"
followed by a valid xml document.  Then it works fine.
I was using openLaszlo not AJAX.
I think I a missing something fundamental.  I am new to AJAX and I am having difficulty understanding exactly what needs
 to be sent back from the server wrt headers and meta data.
Is it possible to get the complete text stream that is returned from the server?
Thanks for the help.
Remember this works for openLaszlo - I haven't used Ajax - but the underlying actionscript is the same.  I use <lf> line
 endings (except as posted above in the header).
Stream can be as minimal as...
<?xml version=\"1.0\"?>
<status>
 <status1>OK</status1>
</status>
Longer stream...
<?xml version="1.0" ?>
<thermodynData>
    <inputs>
        <ts_mode>HEAT</ts_mode>
        <ts_fan>AUTO</ts_fan>
        <ts_temp>72</ts_temp>
    </inputs>
    <outputs>
        <td_temp_in>72</td_temp_in>
        <td_temp_out>60</td_temp_out>
        <td_sys>OFF</td_sys>
        <td_time>04:50p</td_time>
    </outputs>
    <parameters>
        <pm_interval>200</pm_interval>
        <pm_minutes>2</pm_minutes>
    </parameters>
</thermodynData>
My gut says I am still not getting the header to transfer correctly?
In the documentation for slinger it states:
When Slinger executes a CGI script, it parses the output of the script for HTTP header directives. Slinger must buffer
the header directives, before transmitting the script data, in case a header directive is passed that'll affect the
format of the default header directives. Up to 1K of header information can be buffered. CGI scripts must provide a
valid header.
Slinger identifies the end of the header as a blank line, lines are terminated with a <LF> or a <CR><LF>. A common HTTP
header directive to provide specifies the type of data that the CGI script provides. The default Content-Type is "text/
html." For example:
   Content-Type: text/html<LF>
   <LF>
   CGI script data...
However, it does not seem to be capturing any of my stream as a header?  For example, I tried changing the status return
 to 201, but it does not have any effect on the actual status which the XMLHttpRequest object gets.
When I look at the page source for the return I see:
HTTP/1.1 Status: 201 OK Server: custom-cgi Connection: close
Content-Type: text/xml<LF><LF>
<?xml version="1.0"?><quad-1>
<Q1-State>Charge</Q1-State>
<Q1-SubState>Charging</Q1-SubState>
</quad-1>
My XMLHttpRequest object is requesting the page xml_data.shtml from slinger.  The contents of xml_data.shtml is simply:
<!--#config cmdecho="ON" -->
<!--#exec cmd="/usr/web/cgi/TFWeb 1" -->
The cmd line output from "TFWeb 1" is:
<LF>
<quad-1>
</quad-1>
I also tried moving the header data into the shtml file instead of as output from the executable with no affect.
Any ideas?  And again thanks.
The only thing I see is...
vs
From my readings on the web, it is one of the requirements for the responseXML variable to be filled.
Otherwise, I get NULL.
Either way, thanks for the input.  At least you have confirmed that my process is reasonable.
I'll play with this at home over the weekend using apache and PHP to see if I can get it working and maybe learn some
something applicable to the QNX word.
RE: Ajax issue, problems with the responseXML from an XMLHttpRequest
Doesn't look like a valid HTTP response to me.  I believe the spec
(http://www.w3.org/Protocols/rfc2616/rfc2616.html) says everything is
terminated by a <CR><LF> pair which seem to be missing here:
> </quad-1>
I would imagine you want to have:
HTTP/1.1 Status: 201 OK<CR><LF>
Server: custom-cgi<CR<LF>
Connection: close<CR<LF>
Content-Type: text/xml<CR><LF><CR><LF>
</quad-1>
Re: RE: Ajax issue, problems with the responseXML from an XMLHttpRequest
No impact.  Thanks though.
Using the intermediate SSI file with the command:
 <!--#exec cmd="/usr/web/cgi/file.cgi" -->
Was causing the problem.
I requested directly from the cgi file using cgi-bin/file.cgi as the url and slinger correctly parsed the header
information.
Once the header was being parsed I can control the settings and successfully fill the responseXML with a valid DOM.
Greg
