Forum Topic - FPU Assembly Instructions: (2 Items)
I'm using ppc405 core on virtex4 fpga that uses apu to implement hardware fp.
I'm running the procnto-400 microkernel.
when i try to use the lfs assebmly insruction  (load float single) a call to emu_init from femu is done.
how can i configure the kernel not to call the femu procedures when floating point instructions are called ?
Re: FPU Assembly Instructions
Another more precise question :
What does the procnto400 kernel does when he catches floating point exception from the cpu ?
Does it try to load the fpemu library and the _math_emulator.
When debugging the assembly step by step after the lfs command it jumps to _math_emulator .
