Forum Topic - _cmdname(): (5 Items)
_cmdname()
_cmdname() doesn't behave the same under 6.3.2 and 6.4 (the same binary build under 6.3.2 )
When run from a machine called value
under QNX 6.3.2 :
cd /net/neutrino/u/mcharest/logc/bin
./testApp
_cmdname() returned ./testApp.
under QNX6 6.4.0
./testApp
_cmdname() returned /net/value/net/neutrino/u/mcharest/logc/bin/.testApp
This is causing grief to our code any way to get the same behavior.  I'm surprise it's different since it is using libc.
so.2 and not libc.so.3
Re: _cmdname()
> under QNX 6.3.2 :
> ./testApp
> under QNX6 6.4.0
> ./testApp
libc.so.2 and not libc.so.3
Proc sets this up when loading the process so it's not
a libc issue.  This looks to have been done on purpose
and it now matches how it's doc'd as behaving.
Re: _cmdname()
As Sean said, this was a bug fix - _cmdname() needs to always return the
full path so that it's a valid file name to open even if the application does
a chdir().
There's no way to get the old behaviour. What kind of grief is it causing
you?
BTW, libc.so.2 is pretty much a shell with just GCC compiler support
routines defined within it. Even if you run a 6.3.2 binary that wants to
use libc.so.2, the vast majority of the functions being invoked are actually
in libc.so.3.
Re: _cmdname()
I've mentioned this change in the 6.4.0 release notes.
RE: _cmdname()
From: Brian Stecher [mailto:community-noreply@qnx.com]
Sent: November-25-08 2:46 PM
To: ostech-core_os
Subject: Re: _cmdname()
a chdir().
you?
Already fix, it`s because we use the output of cmdname which is send to fullpath().  The output is then parsed to
extract some component and the code wasn`t able to handle two /net.
in libc.so.3.
I see
Thanks.
