Forum Topic - How to set TimerTimeout for MsgSendv? : (1 Item)
I've planned to set timeouts for client MsgSendv calls by TimerTimeout:
Code:
int CClient::Write()
  if ( ( fd = name_open("IOV_SVP", 0) ) == -1 )
     printf("Can't find Message Server\n");
     perror("name_open");
     return (-1);
    event.sigev_notify = SIGEV_UNBLOCK;
    timeout.tv_sec  = 1;
    timeout.tv_nsec =  0;
    timer_timeout( CLOCK_REALTIME,_NTO_TIMEOUT_SEND|_NTO_TIMEOUT_REPLY, &event, &timeout, NULL );
    MsgSendv(fd,  send_iov, 2, reply_iov, 2 );
    name_close(fd);
At the server side there is an endless cycle with MsgReceive. I simulate server crash by sleep function. If i want the
clinet be REPLY blocked, i place sleep(10) before MsgReply (after MsgReceive).
Code:
intChID = ChannelCreate(_NTO_CHF_FIXED_PRIORITY);
ptDpp=_dispatch_create(intChID, 0);
if ((attach = name_attach(ptDpp, "IOV_SVP", 0  )) == NULL)
   printf("name_attach Failed");
while(1)
  rcvid = MsgReceivev( attach->chid,  recv_iov, 2, &info ) ;
  sleep(10);
  MsgReplyv( rcvid,  11, reply_iov ,  2 ) ;
  sleep(1);
The problem is timeout doesn't work in case of REPLY blocked client!
Documentation says:
Quote:
MsgSendv() doesn't unblock on SIGEV_UNBLOCK if the server has already received the message via MsgReceivev() and has
specified _NTO_CHF_UNBLOCK in the flags argument to its ChannelCreate() call
But i don't set _NTO_CHF_UNBLOCK for the channel.
Is there any method to set timeout for MsgSendv?
