Forum Topic - New to Adaptive Partitioning, problems on PXA270: Page 1 of 2 (41 Items)
As a first task I'd like to set up a debug partition so a user can telnet and log into a heavily loaded target.
A debug partition was set up : aps -b10 DevDebug
Then io-net and inetd are launched into the DevDebug partition.
pidin sched shows that io-net and inetd are running in the new partition.
After telneting into an unloaded system pidin shows that telnetd and sh are also assigned to the new partition.
But... when the system is heavily loaded we cannot telnet into the target. If we telnet into an unloaded target, then
apply the load, the shell becomes unresponsive until the system again becomes unloaded. If the load continues telnet
eventually disconnects.
It sort of seems like AP isn't working. I thought that maybe the flash driver and inflator needed to also be in the new
partition so commands could be loaded from flash, but shouldn't those threads inherit the new partition?
Heres the output of aps show:
                    +---- CPU Time ----+-- Critical Time --
Partition name   id | Budget |    Used | Budget |      Used
System            0 |    90% |  37.26% |  100ms |   0.000ms
DevDebug          1 |    10% |  62.69% |    0ms |   0.000ms
Total               |   100% |  99.95% |
Here's the output of pidin sched:
     pid tid name               prio cpu ExtSched             STATE
       1   1 procnto              0f   0 System               READY
       1   2 procnto             70r   0 System               RECEIVE
       1   3 procnto             10r   0 System               RECEIVE
       1   4 procnto             10r   0 System               RECEIVE
       1   5 procnto             10r   0 System               RECEIVE
       1   6 procnto             10r   0 System               RECEIVE
       1   7 procnto             70r   0 System               RECEIVE
       1   8 procnto             10r   0 DevDebug             RUNNING
       1   9 procnto             10r   0 System               RECEIVE
       1  10 procnto             10r   0 System               RECEIVE
       2   1 ot/devf-dbpxa270dp  10r   0 System               SIGWAITINFO
       2   2 ot/devf-dbpxa270dp  10r   0 System               RECEIVE
       2   3 ot/devf-dbpxa270dp  10r   0 System               RECEIVE
       2   5 ot/devf-dbpxa270dp  10r   0 System               RECEIVE
       2   6 ot/devf-dbpxa270dp  10r   0 System               RECEIVE
       3   1 oot/devc-serpxa250  10r   0 System               RECEIVE
       4   1 proc/boot/slogger   30r   0 System               RECEIVE
       5   1 proc/boot/pipe      10r   0 System               SIGWAITINFO
       5   2 proc/boot/pipe      10r   0 System               RECEIVE
       5   3 proc/boot/pipe      10r   0 System               RECEIVE
       5   4 proc/boot/pipe      10r   0 System               RECEIVE
       5   5 proc/boot/pipe      10r   0 System               RECEIVE
    8199   1 sbin/inflator       10r   0 System               RECEIVE
    8199   2 sbin/inflator       10r   0 System               RECEIVE
    8199   3 sbin/inflator       10r   0 System               RECEIVE
    8199   4 sbin/inflator       24r   0 System               RECEIVE
   53256   1 sbin/io-net         10r   0 DevDebug             SIGWAITINFO
   53256   2 sbin/io-net         21r   0 DevDebug             RECEIVE
   53256   3 sbin/io-net         18r   0 DevDebug             RECEIVE
   53256   4 sbin/io-net         10r   0 DevDebug             RECEIVE
   53256   5 sbin/io-net         21r   0 DevDebug             RECEIVE
   53256   6 sbin/io-net         17f   0 DevDebug             CONDVAR
   53256   7 sbin/io-net         10r   0 DevDebug             RECEIVE
   53256   8 sbin/io-net         18r   0 DevDebug       ...
Re: New to Adaptive Partitioning, problems on PXA270
Err. I'm confused. Is the debug partition on the target machine you're telnetting into, or is it on the machine you're
telnetting from?
new partition so commands could be loaded from flash, but shouldn't those threads inherit the new partition?
>    53256   2 sbin/io-net         21r   0 DevDebug             RECEIVE   ...
I'm telnetting from a Windows host to a QNX target. Of course this means the partition is also on the QNX target.
RE: New to Adaptive Partitioning, problems on PXA270
One thing I saw was that your devc-pty is not running in the debug
partition.  That is required for telnet AFAIK.
 Cheers,
    Adam
   QNX Software Systems
   [ amallory@harman.com ]
   With a PC, I always felt limited by the software available.
   On Unix, I am limited only by my knowledge.
       --Peter J. Schoenster
> From: Ken Schumm [mailto:community-noreply@qnx.com]
> Sent: Thursday, October 23, 2008 3:25 PM
> To: ostech-core_os
> Subject: Re: New to Adaptive Partitioning, problems on PXA270
means
> http://community.qnx.com/sf/go/post15467
Re: RE: New to Adaptive Partitioning, problems on PXA270
>  Cheers,
>     Adam
Thanks, but moving devc-pty to the debug partition didn't help.
It shouldn't matter since the server thread should inherit cycles from the partition being served, right?
RE: RE: New to Adaptive Partitioning, problems on PXA270
the
I just wanted to mention the pty requirement for telnet.  You should
capture a kernel instrumentation log using tracelogger to gain more
insight on what is going on and hopefully answer why.
 Cheers,
    Adam
Re: RE: RE: New to Adaptive Partitioning, problems on PXA270
To simplify the problem I started a login shell on the serial port. The shell is running in the DevDebug partition with
10% budget. When the target is heavily loaded any command issued on this shell hangs as if it cannot be loaded from
flash. This is the same behavior that occurs on a telnet shell. So it looks the flash driver is not inheriting the cpu
budget from the partition.
RE: RE: RE: New to Adaptive Partitioning, problems on PXA270
Ah, that's different from your original post.  I interpreted that you
could not type at all (ie. no character echo).  Not being able to start
commands is a different ball game.
What shell are you using?
Can you copy the same command/binary to /dev/shmem and attempt to
execute it to see if you can still reproduce the issue?
 Cheers,
    Adam
> Sent: Monday, October 27, 2008 11:09 AM
> To: ostech-core_os
> Subject: Re: RE: RE: New to Adaptive Partitioning, problems on PXA270
The
> shell is running in the DevDebug partition with 10% budget. When the
it
> cannot be loaded from flash. This is the same behavior that occurs on
a
> http://community.qnx.com/sf/go/post15564
Re: RE: RE: RE: New to Adaptive Partitioning, problems on PXA270
Sorry if my original post was not clear, the word "unresponsive" was not specific. Keystrokes always echo, but commands
do not load and execute when the target is under load.
I copied pidin to /dev/shmem, made it executable, applied a load to the target, then tried to run /dev/shmem/pidin from
the serial shell and it would not load and execute.
After reducing the load on the target it ran just fine.
I double checked and the shell is definitely running in the 10% budget DevDebug partition.
RE: RE: RE: RE: New to Adaptive Partitioning, problems on PXA270
What is priority is the CPU load you're running?  Is it a straight CPU
burning example (have you tried that as well?)?
 Cheers,
    Adam
> Sent: Monday, October 27, 2008 11:28 AM
> To: ostech-core_os
> Subject: Re: RE: RE: RE: New to Adaptive Partitioning, problems on
PXA270
not
> specific. Keystrokes always echo, but commands do not load and execute
the
> target, then tried to run /dev/shmem/pidin from the serial shell and
it
> DevDebug partition.
> http://community.qnx.com/sf/go/post15566
Re: RE: RE: RE: RE: New to Adaptive Partitioning, problems on PXA270
The shell is 10r, so anything it loads would be the same.
I wrote a quick program to delay(500) then do a printf and it continues just fine under load. Under load you can also
type at the shell prompt, or just hit enter, and the prompt comes right back.
The problem seems to occur when commands are loaded when the system is very busy.
Even at 10r the partition should get it's budget of cpu cycles, right?
Ken
>  Cheers,
>     Adam
> > To: ostech-core_os
> PXA270
> not
> the
> it
> > DevDebug partition.
> > OSTech
For giggles can you boost the priority of the shell in your debug
partition to 11 (or another higher priority that no other tasks in ANY
partition are running at)?
Have you taken a kernel trace of the scenario yet?
 Cheers,
    Adam
> Sent: Monday, October 27, 2008 1:38 PM
> To: ostech-core_os
> Subject: Re: RE: RE: RE: RE: New to Adaptive Partitioning, problems on
> PXA270
continues
> just fine under load. Under load you can also type at the shell
prompt, or
> very busy.
> Thanks,
> Ken
CPU
> >  Cheers,
> >     Adam
> > > To: ostech-core_os
> > PXA270
was
> > not
execute
to
> > the
and
> > it
budget
> > > DevDebug partition.
> > > OSTech
> http://community.qnx.com/sf/go/post15572
Our highest priority process runs at 80 so I boosted the shell to 81.
It worked.
I'm not quite sure how to capture a kernel trace when this problem occurs, there are no cycles left to do it (can't
connect via tcp/ip or issue commands from the shell when this happens).
>  Cheers,
>     Adam
Maybe you could do something like this on your serial terminal:
  1. # tracelogger -P 81 -c -n0 &
  2. put system under load
  3. try to run pidin:
       # pidin
  4. remove load from system
  5. # slay -f tracelogger
Ideally the time between 1. and 5. will be no more than a couple of seconds.
Ryan J. Allen
Sent: Mon 2008-10-27 18:55
To: ostech-core_os
Subject: Re: RE: New to Adaptive Partitioning, problems on PXA270
It worked.
I'm not quite sure how to capture a kernel trace when this problem occurs, there are no cycles left to do it (can't connect via tcp/ip or issue commands from the shell when this happens).
>  Cheers,
>     Adam
OSTech
http://community.qnx.com/sf/go/post15574
-P is not a 6.3.2 tracelogger option - use on to set the priority.
I would also recommend using direct mapped mode, eg
tracelogger -S32M -M -n0
>        # pidin
cburgess@qnx.com
If it was easy everyone would be doing it :)
Using Colin's suggestion there is now a 12MB event file in /dev/shmem on the target. Unfortunately, any attempt to ftp
it to the host for examination results in an ftp error "550 Not a plain file". I've tried binary and ascii modes with
the same result. Turns out the file looks like a named special file (n set in the permissions mask). If it can't be
ftp'd over to the host it's not of much use :(
The IDE target filesystem view can transfer it (albeit slowly).  Do you have fs-nfs or fs-cifs on the target -that would
 be fastest.
Colin
> http://community.qnx.com/sf/go/post15593
cburgess@qnx.com
The IDE transfer wasn't so bad, maybe a minute.
Thanks.
> fs-nfs or fs-cifs on the target -that would be fastest.
> Colin
>  target. Unfortunately, any attempt to ftp it to the host for examination
> modes with the same result. Turns out the file looks like a named special file
>  (n set in the permissions mask). If it can't be ftp'd over to the host it's
> not of much use :(
> > OSTech
> cburgess@qnx.com
> It worked.
Sorry that isn't quite what I meant.  I still wanted a lowerish priority
but NOT with any other tasks at that priority (even from different
partitions), so I mentioned 11 as the next available, but only you could
really know the answer here.
occurs,
Tracelogger at priority 81 sounds like it should work.  You could log 5
seconds worth of data - so start tracelogger, apply the CPU load and
attempt to telnet in during that time.  After, just remove the load and
transfer the resulting .kev file (default location is /dev/shmem) off
the board and into your IDE for visualization.
 Cheers,
    Adam
ANY
> >  Cheers,
> >     Adam
OK, I first tried the shell priority at 15, which is above photon, graphics, and our gui and below most everything else.
 That didn't work.
Next the shell priority was set to 40, which is above everything except our watchdog kicker and two interrupt threads.
That didn't work either. The watchdog kicker is at priority 80 and only wakes up once a second and writes to a port. One
 of the interrupt threads is at priority 70 to manage the power key (to power the unit off even if the software goes
nuts). The other interrupt thread handles a DSP interrupt at up to 10kHz. This data interrupt is what we can vary with
an ARB to increase/decrease the target load. At 10 kHz there are enough cycles for the GUI to process data and update
the screen at priority 11.
I'll do an event analysis after lunch.
Tracelogger reports a whole bunch of messages like this:
"Help, we're dropping buffers! <736 dropped so far>"
It was running at priority 81.
After examining the event log, what appears to be happening in the case of the serial port shell is that keystrokes from
 the host are sent to devc-serpxa250 (the interrupts show characters arriving), and the driver is echoing the characters
 back to the host terminal, but when the unit is under load the typed in command string is never passed to the shell
(there seems to be no reply done from the serial port driver to a shell).
are there any news available on this issue?
this is a realy intressting thread, cause we are also using APS
and there isn't realy an explanation for this behaviour.
/hp
> /hp
Are you having the same problem?  I thought maybe our situation was unusual.
AW: RE: RE: New to Adaptive Partitioning, problems on PXA270
no, we do not see exactly the same problem.
>Von: Ken Schumm [mailto:community-noreply@qnx.com]
>Gesendet: Montag, 3. November 2008 21:46
>An: ostech-core_os
>Betreff: Re: RE: RE: New to Adaptive Partitioning, problems on PXA270
>> this is a realy intressting thread, cause we are also using APS and
>> /hp
>OSTech
>http://community.qnx.com/sf/go/post15878
Management Board: Dr. Klaus Blickle (Chairman), Dr. Udo Hüls, Michael Mauser, Regis Baudot
