Forum Topic - problems timing using usleep: (2 Items)
I am trying to time a loop.  I want to sleep some so that I am not just spinning and waiting.  The timeout can be
lengthy, 40 to 50 seconds.
I can't use clock() and usleep() as the latter affects the former (which makes sense I guess, but not what I expected).
I have tried to use clock_gettime() and to use nanosecond math.  That requires large ints and uint64, et. Al. don't seem
 to accept anything larger than a 32 bit value.
I could do a more complex comparison using timespecs without the nanosecond math, but it seems like I'm fighting one
problem after another.
Am I on the right track at all?  What is the best way to timeout a loop and still include some type of sleep so that I'm
 not constantly spinning?
Thanx
Tim
Re: problems timing using usleep
I have been successful getting the clock_gettime method using nanoseconds to work (solved the problem with large
interger math) but I would still be interested in hearing any thoughts if I'm on the right track.  Is there another
solution which might be a better approach.
Here is a example
while (... )
// read some value from a device
usleep(...)
if ( elapsed > timeout )
break;
Thanx
Tim
