Forum Topic - Using resmgr_msg_again to implement blocking read: (5 Items)
I am writing a resource manager and am trying to implement a blocking read.  I am saving the rcvid from the original
read request.
I have used select_attach to wait for data from another file descriptor.  When that descriptor comes ready, my attached
function reads the data from that file descriptor.  I would like to satisfy the original read request by using
resmgr_msg_again and my saved rcvid, however the context structure passed in is a select_context_t instead of the
resmgr_context_t that resmgr_msg_again requires.
The compiler doesn't like me passing in the select_context_t, which seems reasonable.  Is there any way for me to obtain
 the resmgr_context_t from the select_context_t pointer I have?
Is there a better way to do this in general?
Re: Using resmgr_msg_again to implement blocking read
>  read.  I am saving the rcvid from the original read request.
>  descriptor.  When that descriptor comes ready, my attached function
>  the original read request by using resmgr_msg_again and my saved
>  instead of the resmgr_context_t that resmgr_msg_again requires.
>  seems reasonable.  Is there any way for me to obtain the
The problem with resmgr_msg_again() is that it will 'replay' the
original message all over again, which is pretty inefficient.
Since you are already saving the rcvid (and presumably doing any
validation required for the read request) you might be better off
saving a bit more state information yourself (ie offset and read
length) and then when you get the data in the select_attach() callback
use MsgWrite() and/or MsgReply() to send the data to the client
that called read() directly.
Hope this helps,
 Thomas
I have a question related to this thread. A resource managers read/write handlers receive the following parameters:
int ioWrite(resmgr_context_t* ctp,
               io_write_t*       msg,
               iofunc_ocb_t*  ocb)
and
int ioRead(resmgr_context_t* ctp,
               io_read_t*        msg,
               iofunc_ocb_t*  ocb)
In the situation where these read/write requests are deferred (e.g. the caller is blocked until there is data available
to read/write and _RESMGR_NOREPLY is returned), can any of the above pointers be safely saved and subsequently
referenced later when the request is finally handled? Ideally, I'd like to create a client structure that contained
copies of the above pointers as the context of the call and use these parameters later to complete the request (whether
it's a read/write). The client structures are maintained in a linked-list owned by the resource manager until the
original request is handled. Are any of the pointers provided by the read/write handlers destroyed when the functions
return (if they're not immediately satisfied and _RESMGR_NOREPLY is returned). What can I assume is safe to cache and
access later?
The ctp and msg pointers point to the threads context, and cannot be saved (since the msg will be overwritten the next
time a thread receives a message)
You will need to allocate your own pending request structure and save the pertinent info there.
Colin
>                io_write_t*       msg,
>                iofunc_ocb_t*  ocb)
> and
>                io_read_t*        msg,
>                iofunc_ocb_t*  ocb)
available to read/write and _RESMGR_NOREPLY is returned), can any of the above pointers be safely saved and subsequently
access later?
> http://community.qnx.com/sf/go/post15228
cburgess@qnx.com
To be clear, for a single-threaded resource manager, it would be kosher to cache the ocb pointer, right???
I need a reference to the ocb so I can update the "time" if it's a deferred write.
