Forum Topic - Runmasks with IPC and procnto: (6 Items)
I've a few multicore runmask questions.
It was observed that a thread (bound to CPU1) calling  fork()  (thus passing on its runmask) could cause [significant]
activity on CPU0, i.e. outside its runmask.
The cause for that was -in a nutshell-  fork()  is effectively a message pass to procnto, and message passing transfers
priority and partition info, but not runmasks, so procnto is more or less free to run wherever it likes.
The runmask for the new process is not set until the process manager is almost done with the call.
So the following questions arise:
Why is runmask info -other than, e.g., priority- not propagated by message passing?
If always passing runmasks should turn out to be impractical, couldn't at least the process manager try to respect its
client's runmask?
Are runmasks respected in true kernel calls?
Is the general expectation legitimate? Or, in other words, is there a way to dedicate a specific CPU to one  specific
task with very tight realtime requirements?
- Thomas
Re: Runmasks with IPC and procnto
> on its runmask) could cause [significant] activity on CPU0, i.e. outside its
> runmask.
> to procnto, and message passing transfers priority and partition info, but not
>  done with the call.
> passing?
> least the process manager try to respect its client's runmask?
> dedicate a specific CPU to one  specific task with very tight realtime
> requirements?
> Thanks,
> - Thomas
If runmask would be propragated wouldn't that fold the fabric of space. If devb-eide is set to run on CPU2 and a process
 set to run on CPU3 tries to read a file, kaboom, much worst then a division by 0.
AW: Runmasks with IPC and procnto
> -----Ursprungliche Nachricht-----
> Von: Mario Charest [mailto:community-noreply@qnx.com]
> Gesendet: 08 October 2008 15:15
> An: ostech-core_os
> Betreff: Re: Runmasks with IPC and procnto
> > Hi,
> i.e. outside its
> > runmask.
> it likes.
> >  done with the call.
> > passing?
> is there a way to
> tight realtime
> > requirements?
> > Thanks,
> > - Thomas
Not necessarily - as with NTO_CHF_FIXED_PRIORITY (was that the name?)
you might get a choice of either sticking to your own runmask or using
whichever is provided to you by the client.
Then again - if a "floating mask" server is servicing a request with
runmask 0x1 and another client tries to send with runmask 0x2, will
the server finish the first client's request with a runmask of 0x1,
0x2, or 0x3 ???
- thomas
> http://community.qnx.com/sf/go/post14680
RE: Runmasks with IPC and procnto
During a message passing, we always *try to* schedule the waked up
server thread to the same CPU as the sending client. This is to probably
utilize the hot cache on that CPU (likely the data the client is sending
is already in the cache), and of cause we know that CPU is going to be
free (as the client will be blocked)
Of cause, if you put a Runmask on server, then it follow the runmask.
-xtang
From: Thomas Haupt [mailto:community-noreply@qnx.com]
Sent: October 8, 2008 9:26 AM
To: ostech-core_os
Subject: AW: Runmasks with IPC and procnto
> An: ostech-core_os
> > Hi,
> i.e. outside its
> > runmask.
> it likes.
> >  done with the call.
> > passing?
> is there a way to
> tight realtime
> > requirements?
> > Thanks,
> > - Thomas
0x2, or 0x3 ???
- thomas
OSTech
http://community.qnx.com/sf/go/post14682
We also have the issue that the loader thread doesn't not set it's runmask
to that of the process being created.  This means that if you have a process
bound to a cpu, and then spawn another process (with the inherited runmask), then
the loader thread can still cause activity on another CPU.  This is noted as a PR and
will be worked on post 6.4
> -xtang
> To: ostech-core_os
>> An: ostech-core_os
>>> Hi,
>> i.e. outside its
>>> runmask.
>> it likes.
>>>  done with the call.
>>> passing?
>> is there a way to
>> tight realtime
>>> requirements?
>>> Thanks,
>>> - Thomas
> 0x2, or 0x3 ???
> - thomas
>> OSTech
> http://community.qnx.com/sf/go/post14684
Right, we had that already - I almost forgot about the loader thread.
Do you think this will take very much effort?
> Von: Colin Burgess [mailto:community-noreply@qnx.com]
> Gesendet: 08 October 2008 15:37
> An: ostech-core_os
> it's runmask
> have a process
> is to probably
> client is sending
> going to be
> the runmask.
> > -xtang
> > To: ostech-core_os
> >> An: ostech-core_os
> >>> Hi,
> >> i.e. outside its
> >>> runmask.
> >> it likes.
> >>>  done with the call.
> >>> passing?
> >> is there a way to
> >> tight realtime
> >>> requirements?
> >>> Thanks,
> >>> - Thomas
> the name?)
> > you might get a...
