Forum Topic - Abstract Domain Sockets (Unix domain sockets): (5 Items)
I am in the process of porting DBUS from Linux onto QNX 6.3.2. DBUS uses unix domain sockets as the communications
channel between services. Fortunately, it appears that QNX does support unix domain sockets. Specifically, however, DBUS
 seems to want to use a variant called "abstract" domain sockets that are supported under Linux (and I think Sun). I
guess "abstract" domain sockets appear in the filesystem but they're not quite "real". Regardless, they're signified by
stuffing a NULL (\0) as the first byte of the path in the address structure (as seen below):
addr.sun_path[0] = '\0'; /* this is what says "use abstract" */
The actual path to the "domain" socket is appended to the end
strncpy (&addr.sun_path[1], path, path_len);
Unfortunately, it appears QNX chokes hard on this and actually corrupts the '.' and '..' entries in the filesystem after
 a call to "bind". I discovered this when running an autoconf "configure" script and it hung at the end. When I hit ctrl
-c to kill the build I was left at the shell prompt. From there I could no longer "ls" the current directory I was in
(although 'ls' would work if I specified a complete path). I suspect one of the configure tests tried to execute an
abstract domain socket test application to determine if it was supported (and apparently it believes so from the output
of config.log). Needless to say, the only recovery is to restart QNX (hard to believe a shell script can so easily take
out the QNX filesystem).
So, the question I have is whether QNX supports abstract domain sockets, and if so, how do you signify that they are
abstract to the OS?
Also, I suspect QNX might want to "harden" or scrub the input parameters to "bind" a little more carefully and at least
return an error if abstract sockets aren't supported. No sense trashing the file system.
RE: Abstract Domain Sockets (Unix domain sockets)
No, we do not do the "abstract name" (though it is not harder to do so).
I believe the configure file in DBUS actually do a test on this feature,
and the source is also happy
if the OS does not support "abstract name".
On core_network 6.4, we made the stack FAIL if a Unix domain path
started with a NULL, this way,
the configure would detect, and do the right thing.
Unfortunately, on 6.3.2 the configure fill will mess up things badly.
You can try modify the configure
file to exclude the test of "abstract name" and specifically set it to
fail, to get your porting going.
By the way, if you happened to get into the bad status (no . and ..),
kill the stack (the io-net process)
should bring everything back. (you then have to restart it by hand of
cause).
If you are not using configure file, but rather messing with the source
yourself, either define the flag
to tell DBUS not to do it, or modify the source so it won't have a
leading NULL in path.
-xtang
> From: Glenn Schmottlach [mailto:community-noreply@qnx.com]
> Sent: Friday, August 08, 2008 4:48 PM
> To: ostech-core_os
> Subject: Abstract Domain Sockets (Unix domain sockets)
> after a call to "bind". I discovered this when running an
> hit ctrl-c to kill the build I was left at the shell prompt.
> in (although 'ls' would work if I specified a complete path).
> take out the QNX filesystem).
> abstract to the OS?
> http://community.qnx.com/sf/go/post11598
Re: RE: Abstract Domain Sockets (Unix domain sockets)
Thanks for the information. That should save me some time.
Do you know if anybody (possibly QNX) has already ported DBUS, and if so, is the source available?
RE: RE: Abstract Domain Sockets (Unix domain sockets)
The DBUS in "QNX Community pkgsrc Project" build just fine, provide you
have the latest network stuff so you don't get caught in the UDS
problem.
-xtang
> Sent: August 8, 2008 5:32 PM
> To: ostech-core_os
> Subject: Re: RE: Abstract Domain Sockets (Unix domain sockets)
so, is
> http://community.qnx.com/sf/go/post11601
Hi Glenn:
We specifically look for and invalidate abstract UD sockets with the new
version of our networking stack so that you don't see this corruption
(see commit
http://community.qnx.com/sf/scm/do/viewCommit/projects.networking/scm.Co
re_Networking/cmmt11186).
The older, currently shipping version of the stack doesn't behave
properly, unfortunately, as you have found out.
   Robert.
To: ostech-core_os
unix domain sockets as the communications channel between services.
Specifically, however, DBUS seems to want to use a variant called
Sun). I guess "abstract" domain sockets appear in the filesystem but
they're not quite "real". Regardless, they're signified by stuffing a
seen below):
the '.' and '..' entries in the filesystem after a call to "bind". I
at the end. When I hit ctrl-c to kill the build I was left at the shell
of the configure tests tried to execute an abstract domain socket test
so from the output of config.log). Needless to say, the only recovery is
to restart QNX (hard to believe a shell script can so easily take out
and if so, how do you signify that they are abstract to the OS?
to "bind" a little more carefully and at least return an error if
OSTech
