Forum Topic - IPI_CHECK_INTR handling: (4 Items)
I am trying to understand the handling of IPI_CHECK_INTR on a system with two x86 processors.
From what I understand, looks like a CPU issues IPI_CHECK_INTR interrupt to next CPU at the end of interrupt handling if
 INKERNEL_NOW and  INKERNEL_EXIT bits are set. Now, during the handling of IPI_CHECK_INTR, next CPU is executing the
same code path and bouncing this interrupt back to the first one if value of inkernel hasn't changed. Is this the
expected behaviour?
Thanks in advance for any explanation.
Prasad Lingutla
Re: IPI_CHECK_INTR handling
> to next CPU at the end of interrupt handling if INKERNEL_NOW and
> next CPU is executing the same code path and bouncing this interrupt back
> to the first one if value of inkernel hasn't changed. Is this the expected
> behaviour?
The IPI_CHECK_INTR is only sent if this CPU was _not_ in the kernel
(it wasn't the one that set INKERNEL_NOW) _and_ the other one was (more
generally, some other CPU was). In that case the CPU exiting the interrupt
handling can not enter the kernel to process any pending interrupt
events, so it passes the job to the guy who's already in the kernel
and can. The other CPU will receive the IPI and on its way out of the
interrupt processing will notice if there are any high priority pending
events. If so, it'll preempt the kernel call in progress to deal with
them. If not, it'll complete the kernel call and deal with the pending
events when leaving the kernel. It won't bounce back the IPI since it's
in the kernel already.
Thanks for your explanation Brian.
In my case, I am noticing CPU 0 handling a flood of interrupts from a
faulty device, while CPU 1 is running the idle thread.  IPI_CHECK_INTR
bit is set in ipicmds[0] and CPU 0 LAPIC's Interrupt Request Register
shows IPI is in the queue. First frame on CPU 0 stack is in function
kernel.S:enoerror(), right after setting the kernel lock & exit flags in
inkernel and enabled the interrupts. I think this is done while exiting
from interrupt processing. This indicates that kernel lock is held by
CPU 0 and it is busy handling interrupts.
I was trying to see if there is a way for CPU 1 to process the interrupt
event queue in such a situation. But from your explanation, looks like
thats not going to happen until  the lock is released by CPU 0.
Thanks again,
Prasad
-------- Original Message  --------
Subject: Re: IPI_CHECK_INTR handling
To: ostech-core_os <post11438@community.qnx.com>
Date: 08/05/08 07:04
>> behaviour?
Correct. CPU 0's got to get out of the kernel first (which will cause
it to process the pending list anyway).
	Brian
while exiting
> Thanks again,
> Prasad
> From: Brian Stecher <community-noreply@qnx.com>
> >> behaviour?
> http://community.qnx.com/sf/go/post11763
