Forum Topic - Changing monotonic timer: (3 Items)
Hi
I need to simulate situation when software runs for long time. Is there a way to change monotonic timer so that it
returned more than 0x10 0000 0000 0000? I know there is no legal way, but I'm OK with a hack like writing the memory in
_syspage_ptr->qtime (unfortunately it appears to be mapped as read-only). How can I determine physical address of that
memory? Can I modify it via /dev/mem?
Thank you in advance.
Re: Changing monotonic timer
> Hi
> to change monotonic timer so that it returned more than 0x10 0000 0000 0000? I
>  can I determine physical address of that memory? Can I modify it via /dev/mem
I guess you could find the physical address via mem_offset64, then mmap it with write permission.
It works. Thank you.
