Forum Topic - sem_unlink() behavior: (2 Items)
The neutrino (I assume posix?) "feature" that a named semaphores outlives the process which created it, seems to make
their use complicated.
For example, if a second instance opens a named semaphore created by a previous instance, the state of the semaphore
cannot be trusted - i.e. the first process may have left the semaphore with a count of zero due to a trap OR it may be
holding the semaphore intentionally - SO the second process cannot reliably "wait" AND neither can it "unlink" it since
it may be valid!
After reading the following, I thought the creator instance could issue sem_unlink() which would be DELAYED until all
instances had closed the semaphore ... BUT nto does not work this way... in fact sem_unlink() removes the named
semaphore EVEN WHILE the creator still holds it open i.e. there is no "delayed" unlink in nto!
http://www.opengroup.org/onlinepubs/007908799/xsh/sem_unlink.html
"The sem_unlink() function removes the semaphore named by the string name. If the semaphore named by name is currently
referenced by other processes, then sem_unlink() has no effect on the state of the semaphore. If one or more processes
have the semaphore open when sem_unlink() is called, destruction of the semaphore is postponed until all references to
the semaphore have been destroyed by calls to sem_close(), _exit(), or exec. Calls to sem_open() to re-create or re-
connect to the semaphore refer to a new semaphore after sem_unlink() is called. The sem_unlink() call does not block
until all references have been destroyed; it returns immediately."
Suggestions on how a subsequent instance may reliably use an existing named semaphore would be appreciated.
Dennis
Re: sem_unlink() behavior
> sem_unlink() which would be DELAYED until all instances had closed the
> the named semaphore EVEN WHILE the creator still holds it open i.e. there is
If they work like shared memory after an unlink, it still exists but it's not accessible.  You cannot see it anymore (
for example with ls ) but it's still  there.  I assume named semaphore behave the same.
