Forum Topic - MakeFile: (4 Items)
MakeFile
How to Write a Makefile in QNX? Any materials will be helpful
Re: MakeFile
We use GNU make, so in general any makefile information you find will
be applicable.
If your interested in QNX makefile specifically, firstly you should keep
in mind that QNX makefiles can be managed via the IDE quite well. But if
your interested in the details the following link describes our
makefiles quite well:
http://www.qnx.com/developers/docs/6.3.2/neutrino/prog/make_convent.html
Joel
> http://community.qnx.com/sf/go/post9896
Re: MakeFile
I wanted to write a makefile that should also compiles .h files, if there is any change. please suggest.
Re: MakeFile
If you asking how to compile a header as a c file, specify -xc (both qcc and gcc drivers accept it). Precompiled headers
 are another story.
The following is a very simple example of what I assume you're trying to do:
$ cat makefile
foo: t.h
        $(CC) -xc t.h -o foo
$ make
cc -xc t.h -o foo
$ make
make: `foo' is up to date.
$ touch t.h
$ make
cc -xc t.h -o foo
Ryan Mansfield
