Forum Topic - Query on having environment of Parent in child process...: (3 Items)
I am porting an application from Linux to QNX. The application has threads and also does fork+exec. The part of code is
as follows.
setenv(a);
if(fork() == 0)
    setenv(b);
else
    return;
execvp();
I read from the netrino programing document that process having threads fail to fork. And instead of fork+exec I have to
 call spawn(). But how do I get the environment of parent and also some environment set after fork() specifically for
the child process?
Thank you.
Amit
AW: Query on having environment of Parent in child process...
you could provide a complete (extended) environment explicitly as the
last argument to the spawn() call, but that'd call for a bit of work.
I think the easiest would be to do
  setenv(a,a_val);
  setenv(b,b_val);
  spawn( ..., NULL );   // envp=NULL --> inherit environment
  setenv(b,NULL);       // unset b
- Thomas
> -----Ursprungliche Nachricht-----
> Von: Amit Gourgonda [mailto:amitg@openclovis.com]
> Gesendet: 20 June 2008 07:40
> An: ostech-core_os
> Betreff: Query on having environment of Parent in child process...
> code is as follows.
> setenv(a);
> if(fork() == 0)
>     setenv(b);
> else
>     return;
> execvp();
> to call spawn(). But how do I get the environment of parent
> the child process?
> Thank you.
> Amit
> http://community.qnx.com/sf/go/post9449
Re: Query on having environment of Parent in child process...
spawn() accepts an environment pointer which can be used to "construct"
an environment of your choice for the spawn()'d process. If you pass
NULL, your spawn()'d process will inherit the parents environment.
Amit Gourgonda wrote:
is as follows.
> setenv(a);
> if(fork() == 0)
>     setenv(b);
> else
>     return;
> execvp();
to call spawn(). But how do I get the environment of parent and also some environment set after fork() specifically for
the child process?
> Thank you.
> Amit
