Forum Topic - Phfont crashes on M6: (9 Items)
Not sure this is the best place for such a report.
When running M6 and trying to connect to the machine with Phindows, phfont crashes right away. The same machine with a 6
.3.2 kernel works just fine.  I'm assuming this is not a phfont problem, but attached the dump file anyway.
Attachment: Text phfont.core.7z 456.98 KB
Re: Phfont crashes on M6
> crashes right away. The same machine with a 6.3.2 kernel works just fine.  I'm
Ping
Tried with M7, same thing
> I'm
> Ping
Hi Mario,
The photon guys don't have this environment setup right now, and they are deeply embroiled in 6.4.0 work.
Would you be able to post a backtrace - they may be able to spot something.  Certainly, photon has changed quite a bit
(in the backend) for 6.4
Cheers,
Colin
> Hi Mario,
VMWare to the rescue... ;-)
(gdb) backtrace
#0  0xb0355453 in ?? ()
#1  0xb8218802 in ?? ()
#2  0xb032fef2 in ?? ()
#3  0xb032ec82 in ?? ()
#4  0xb821f2b0 in ?? ()
#5  0xb821ddf6 in ?? ()
Not sure that is what you meant. You can get this whatever the environment you are working from.
> Certainly, photon has changed quite a bit (in the backend) for 6.4
Just to be clear, I'm getting this on a 6.3.2 machine which only has the 6.4 kernel from M7.
> Cheers,
> Colin
Backtrace, yes - symbol names, no. :-)
cburgess@qnx.com
Even though the backtrace looks good (no 0xdeadbeef), it is a bit useless ;-).
Need more info:
1. Slog messages?
2. Do you create a new Photon session or ditto of an existing sessions?
3. Try not to run phfont at all.
4. ls -l /dev/phfont*
5. ls -l /usr/bin/phrelay
Really ?
I put a experimental phrelay ( one with support for clip board ) that i was given a while back ( 2006 ) and it doesn't
crash anymore.
If you think this is worth investigating I could but the original phrelay to help you out, but as far as I'm concern
I'll be moving on  ;-)
done! -)
