Forum Topic - How not to pollute app w/proprietary API calls?: (3 Items)
In the Neutrino library reference, some functions are classified as Posix, but others are classified as Neutrino (e.g.
InterruptAttach). Does that mean no Posix function exists for attaching interrupts? I would like to avoid the use of
proprietary API calls in my code to the extent possible.
Re: How not to pollute app w/proprietary API calls?
Hi Jonathan,
No, POSIX doesn't specify interfaces for attaching to interrupts.  In
general dealing with
interrupts is very OS specific.  At best you can write wrapper
routines/macros.
but others are classified as Neutrino (e.g. InterruptAttach). Does that mean
use of proprietary API calls in my code to the extent possible.
> http://community.qnx.com/sf/go/post8380
cburgess@qnx.com
> Posix, but others are classified as Neutrino (e.g. InterruptAttach).
> I would like to avoid the use of proprietary API calls in my code to
There's usually a note in the library reference entry giving the equivalent
POSIX functions and saying you should use those (where they exist) and
the "See Also:" section would have the POSIX API's listed as well.
