Forum Topic - usblauncher_otg: (1 Item)
usblauncher_otg
I'm trying to get auto-mounting of USB devices (mainly umass) working on the RPi4 and Xilinx MP-SOC's (both aarch64le).
With the help of the QNX support guy I managed to start pps and provide the correct arguments to usblauncher_otg and
have it create entries in /dev. It started devb-umass and when I insert a simple thumbdrive (either with a t12 or t177
partition) it simply cretes /dev/umass0, /dev/umass1, and /dev/umass2. Using fdisk, only the umass2 shows a valid
(support) filesystem partition (12 and 177 respectively). I start usblauncher_otg as follows:
usblauncher_otg -vvv -E -e -0 -m /pps
I am not seeing anything in the output log indicating anything wrong. It sees the thumbdrives being inserted and removed
 - it simply won't mount any partition (under /fs or anywhere else).
I'm using the supplied rules.lua and rules.mnt files but it simply won;t mount either of these partition types to
produce /fs/usb0, /fs/usb1, etx.
I am wondering is this is because there are no /dev/umass2t12 or /dev/umasst177 entries?
If so, who/what actually does this. Is it devb-umass that looks into the umass device to see what partitions are there
and create/mount them so that a later mount will work? The arguments provided to devb-umass are quite numerous and are
based (I think) on what is in the rules.lua file.
Apparently I should see in the usblauncher_otg output log entries referring to do_mount_fsys. But I don't. And I can't
find out why - this stuff doesn't seem to be documented much - or if it is it's hard to find.
The other mystery with this is why I see /dev/umass0 and /dev/umass2 - neither of which relate it seems to any supported
 partition type. I don't see this when I manually and mionimally start devb-umass cam pnp name=umass.
Can someone provide some enlightenment please? I'm struggling a bit with this one! :-)
Geoff.
