Forum Topic - Is this a an valid configuration file: (9 Items)
or just an incomplete example  of pci_hw-template.cfg?
# Example entry
# For the second device with VID/DID 0x1234/0xabcd, use 16MB for BAR 1, 256MB
# for BAR 3 and 1 MB for BAR 5 (none of these could be 64 bit BAR's)
# 1234;abcd;1;1:8;3:12;5:4
#############################  S E C T I O N  ##################################
[interrupts]
# PCI Interrupt Pin Assignments and IRQ mappings
[slots]
# Chassis and Slot Mappings
[aspace]
# Address Space
# ASPACE_FILTER=
[rbar]
# Resizable BAR Overrides
Re: Is this a an valid configuration file
template files exist to document the usage and use examples to do that. They are not expected to be used as is.
What entry in particular is causing confusion?
Do we have to fill out all sections?  Or is it optional?
We have just to assigne the Interrupt for a decent PCI board ...
all parameters within a config file are optional as is the use of a config file itself.
You need only add entries for the parameters you wish to control/alter
Armin, as an aside, I believe you had commented in this forum previously about having problems with IRQ assignments for
legacy devices (in which MSI/MSI-X was not supported). Without having the details, I believe this is probably related to
 missing chipset support in the SDP7 released version of the Intel HW module which was version 2.0. This module is now
at revision 2.4 and among other changes, includes support for many (but perhaps still not all) of the newer chipsets.
You should be able to obtain access to this HW module by contacting your sales rep or FAE
Some PCI Local Bus Specification Revision 2.1 based  audio interfaces are supported by QNX 7.0!
That means it should be possible to support other  PCI Local Bus Specification Revision 2.1 based  PCI boards.
The PCI server is able to assign memory to the PCI config space, a PCI config file allows to generate an OS image with
an Interrupt assigned to an individual PCI 2.1 device.
What's the problem?  Is the PCI lib of QNX7 ignoring PCI 2.1 based devices?
I had already replied to previous posts that we do not explicitly exclude any version of PCI device.
The problem description you provide does not give any real insight into what specific problem it is you are having.
Perhaps collect some pci-tool output, slog2info etc and we may be able to assist you
Sorry, it isn't true for versions of QNX 6.x.
The support of  devices based on the parallel PCI bus is a littlebit lousy under QNX 7.x
The fact that we have to create speciallized OS images for parallel bus PCI devices could be better.documented!!
> assist you
My question was:"A fter creating an adapted OS Image - for manually assigning an IRQ - are parallel bus PCI devices
fully supported??".
BTW ... long time ago, I provided a screendump of pci-tool showing that no IRQ has been assigned!!
I haven't seen hints about PCI config files a.s.o.
Regards
Armin
The output of pci-tool isn't correct. It doesn't show the real assigned
IRQ and its pin!! Please see my last posting!
Also: the assignment of IRQs by the pci-server is weak documented ...
however its seems not yet implemented!
That means at the end -> the support of local bus PCI devices is
currently not existent!
Armin
> PS:  slog2info etc and we may be able to assist you
really ?
> http://community.qnx.com/sf/go/post120835
