Forum Topic - Can I use long double without losing precision?: (2 Items)
std::istringstream is losing precision when converting a string to long double.
Some people told me it is because an 80-bit double (long double) is not large enough to store the number. Is this issue
related to QNX itself or some compiling flags are missing?
To demonstrate the problem, I wrote this code:
#include <iostream>
#include <string>
#include <sstream>
#include <iomanip>
int main(){
    long double convertedNumber;
    std::string numberString ("5.94865747678615882510631e+4931");
    //From string to long double
    std::istringstream iss(numberString);
    iss >> convertedNumber;
    std::cout<< std::setprecision(30) << numberString << "\n";
    std::cout<< std::setprecision(30) << convertedNumber << "\n";
    return 0;
The output is always:
5.9486574767861588254e+4931
Compiled with:
QCC -V5.4.0,gcc_ntox86_64 main.cpp -o qnxTest -std=gnu++14
Re: Can I use long double without losing precision?
long double is defined as 80 bits in size with a certain internal structure by some IEEE standard. So in my opinion,
this is not a QNX related issue.
But you could easily check that by having your code compiled for a Linux box and observe the output.
Al
