Forum Topic - Signal Handler for Stack Overflow: (6 Items)
We are trying to create signal handler to catch stack over flow exception for our application on target. Can any one
help us to do the same.
Thank you in Advance.....
Thanks & Regards
Sai
RE: Signal Handler for Stack Overflow
*If* the stack has a guard page and *if* the overflow hits this page (it can also jump over it, e.g. by writing to a
high element in a large stack-allocated array) then the process will receive a SIGSEGV signal. Otherwise it may receive
SIGBUS or nothing at all (the overflow just goes on to an adjacent mapped region). In general there is no deterministic
way to detect a stack overflow.
--Elad
Sent: December-18-18 8:11 AM
To: ostech-core_os
Subject: Signal Handler for Stack Overflow
Thanks & Regards
Sai
OSTech
http://community.qnx.com/sf/go/post119361
Re: Signal Handler for Stack Overflow
Some ideas, although none of them will be ideal as Elad mentioned.
1) If single-threaded process, attach signal handler such that SIGINFO is enabled. The signal code and the si_addr
should tell you if something went wrong in the stack.
 * SIGSEGV codes (si_addr == address of faulting memory reference)
#define SEGV_MAPERR	1	/* Address not mapped */
#define SEGV_ACCERR	2	/* No permissions */
#define SEGV_STKERR	3	/* ?? Stack exception */
#define SEGV_GPERR	4	/* ?? General protection */
#define SEGV_IRQERR	5	/* ?? Interrupt handler fault */
#if defined(__EXT_QNX)
#define NSIGSEGV	5
#endif
I do not know what the question marks mean, though.
2) Allocate all the stacks to be guarded yourself, create large enough guard page and fill stack with a well-known
pattern. Create an additional thread which will periodically scan all the threads' last valid page if the pattern is
still there (may cause realtime penalty).
Albrecht
1) won't work, since the signal handler can't be invoked - it will try to use the the same stack that originally
overflowed. Neutrino doesn't have support for alternate signal handler stacks.
Sent: December 18, 2018 9:13 AM
To: ostech-core_os
Subject: Re: Signal Handler for Stack Overflow
#define NSIGSEGV        5
#endif
Albrecht
OSTech
http://community.qnx.com/sf/go/post119364
Re: RE: Signal Handler for Stack Overflow
Thanks for clarifying Brian. What would work, to best of my belief, is to have a dedicated thread sitting in
sigwaitinfo(), and have all other threads block all signals, so as to have a single point where to handle signals. If
sigwaitinfo() is set up such that the SI_INFO is delivered by kernel, you should be able to see what the original thread
 was, and SI_CODE/SI_VALUE will tell you the reason.
Having the main Thread 1 go to SIGWAITINFO after spawning off all the real worker threads seems to be a commonly used
design pattern in QNX drivers, looking at a "pidin" output of a regular machine.
Albrecht
RE: RE: Signal Handler for Stack Overflow
Sorry, that won't work here either. Signals caused by CPU exceptions (SIGSEGV, SIGBUS, etc) are always delivered to the
thread (and on its stack) that caused the exception. Blocking such a signal on the thread will just cause the process to
 be terminated when the CPU exception occurs. Blocking signals and having a single thread deal with them only works for
software initiated ones (SIGQUIT, SIGTERM, etc).
Sent: December 18, 2018 9:39 AM
To: ostech-core_os
Subject: Re: RE: Signal Handler for Stack Overflow
Albrecht
OSTech
http://community.qnx.com/sf/go/post119366
