Forum Topic - How to check hyperthreading status using CPUID: (4 Items)
I found this instruction from one of the intel documentation on how to check hyperthreading(HTT) support.
"To determine if Hyper-Threading Technology is supported, check the value returned in EBX[23:16] after executing
CPUID with EAX=1. If EBX[23:16] contains a value >1, then the processor supports Hyper-Threading Technology"
I am using below code to check the same:
void cpu_ID(unsigned int Info, unsigned int ui[4]) {
    __asm__ __volatile__("cpuid" : "=a" (ui[0]), "=b" (ui[1]), "=c" (ui[2]), "=d" (ui[3]) : "a" (ui), "c" (0));
int main()
    cpuID(1, Info);
    logicalCores = (ui[1] >> 16) & 0xff; // EBX[23:16]
    printf("logicl core %d \n",logicalCores);
I always get logical cores greater than 1.
If i search the featurs of my processer online it is mentioned that Hyper threading is NOT SUPPORTED.
Is there any mistake the way am using CPUID and calculation.
Also please let me know if there is a better alternative for
checking if system has HTT support and weather it is enabled or disabled.
Thank you for the support
Re: How to check hyperthreading status using CPUID
> int main()
>     cpuID(1, Info);
I was not able to edit the above code i posted so i am posting the code in reply ::
    __asm__ __volatile__("cpuid" : "=a" (ui[0]), "=b" (ui[1]), "=c" (ui[2]), "=d" (ui[3]) : "a" (info), "c" (0));
int main()
    unsigned int ui[4];
    cpuID(1, ui);
RE: How to check hyperthreading status using CPUID
Your question has nothing to do with QNX and is better asked on Intel forums.
From a cursory glance around the internet it seems that bit 28 is used to indicate both HT and multi-core. In order to
find whether HT is used you need to enumerate all cores and then compare logical with physical ones. See
https://software.intel.com/en-us/articles/intel-64-architecture-processor-topology-enumeration/
--Elad
From: Surya kumar(deleted) [community-noreply@qnx.com]
Sent: November-27-18 2:14 AM
To: ostech-core_os
Subject: Re: How to check hyperthreading status using CPUID
> int main()
>     cpuID(1, Info);
int main()
    unsigned int ui[4];
    cpuID(1, ui);
OSTech
http://community.qnx.com/sf/go/post119308
Re: RE: How to check hyperthreading status using CPUID
Thanks Elad .
