Forum Topic - how to USB-WIFI ?: (1 Item)
how to USB-WIFI ?
Hi QNX,
             beaglebone black, QNX 6.5SP1, bsp-nto650-ti-beaglebone-sp1-trunk-201209071340, Realtek rtl8192 usb-wifi
adapter
Please help how to configure USB-WIFI in QNX. A previous post in the network forum suggests to compose a device driver,
and gives the source code of asix USB-Ethernet as reference.
http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/discussion.drivers.topc26776?_message=
1540800666226
However, when I look into rtl8192cu linux source code, I don't think I am capable to port it into QNX.
Here is what I am thinking,
According to http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.io-pkt_en_user_guide%
2Fwpa_background.html
io-pkt-v4-hc has 802.11 layer built in, and WPA utilities is able to manage wireless network connections. I am wondering
 whether there is a simple solution and just let build script configures USB-WIFI ?
Currently, in .build script, I have Ethernet and USB-OTG setup as follows,
    io-pkt-v4-hc -dam335x deviceindex=0
    waitfor /dev/socket
    if_up -p -a dm0
    ifconfig dm0 192.168.31.205/16
	display_msg Starting USB OTG Host driver...
	io-usb -vvv -d dm816x-mg ioport=0x47401c00,irq=19
	waitfor /dev/io-usb/io-usb 4
QNX is able to locate the devices,
# usb -vvv
USB 0 (dm816x) v1.10, v1.01 DDK, v1.01 HCD
    Control, Interrupt, Bulk(SG), Isoch(Stream), High speed
Device Address             : 1
Upstream Host Controller   : 0
Upstream Device Address    : 0
Upstream Port              : 0
Upstream Port Speed        : High
Vendor                     : 0x0bda (Realtek)
Product                    : 0x8176 (802.11n WLAN Adapter)
Device Release             : r2.00
USB Spec Release           : v2.00
Serial Number              : 00e04c000001
Class                      : 0x00 (Independent per interface)
Max PacketSize0            : 64
Languages                  : 0x0409 (English)
Current Frame              : 471 (1024 bytes)
Configurations             : 1
  Configuration            : 1
    Attributes             : 0x80 (Bus-powered)
    Max Power              : 500 mA
    Interfaces             : 1
      Interface            : 0 / 0
        Class              : 0xff (Vendor-specific)
        Subclass           : 0xff
        Protocol           : 0xff
        Endpoints          : Control + 4
          Endpoint         : 0
            Attributes     : Control
            Max Packet Size: 0
          Endpoint         : 1
            Attributes     : Bulk/IN
            Max Packet Size: 512
          Endpoint         : 2
            Attributes     : Bulk/OUT
          Endpoint         : 3
          Endpoint         : 4
            Attributes     : Interrupt/IN
            Max Packet Size: 64
            Interval       : 1 mframe
# ifconfig
dm0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	address: 80:30:dc:54:02:97
	media: Ethernet none (100baseTX full-duplex)
	status: active
	inet 192.168.31.205 netmask 0xffff0000 broadcast 192.168.255.255
I tried to follow "Using Wi-Fi with io-pkt"
# io-pkt-v4-hc -d /lib/dll/devnp-ral.so
# ifconfig
which actually kills dm0, and does not invoke ral0 for wifi as well.
Please advice , thanks in advance.
Mike
Attachment: Text build 23.67 KB
