Forum Topic - ROM Memory Calculation: (3 Items)
Hii,
In our application we trying to estimate the ROM memory consumed by all processes which are running currently, for this
we are using "pidin pmem" on target and we are getting code, data and stack memory details of each process. In order to
calculate overall used ROM, we are summing of code and data memory of all processes.
For example:
This is the output of "pidin pmem" output
     pid      tid     name                             prio       STATE               code        data        stack
       1         2     /procnto-smp-instr       255r     RECEIVE           758K     124K      8192(8192)
       3         1      proc/boot/pipe             10r       SIGWAITINFO     712K    744K      8192(516K)*
 1879        1      usr/sbin/qconn            10r       SIGWAITINFO    1084K   888K     8192(516K)*
To calculate overall ROM used,
Total ROM used =  758K+124K+712K+744K+1084K+888K
                               = 4310K
In our case this value is exceeding total available ROM. Is this is the way to calculate total used ROM? If it's wrong
kindly suggest us how to do the same?
Thank you in Advance....
Re: ROM Memory Calculation
Hi Sai,
I suppose you ment RAM but not ROM (so far you add the data segments in your total)...
The easiest way is to stat("/proc", &struct_stat), the "struct_stat.st_size" gives you the current free memory on your
board. Try "ls -la /" on the command line as an illustration.
BR
Hi Alexandre ,
We would like to know used data segment memory only on our board but not RAM memory.
Thank you...
