Forum Topic - cross-cpu synchronization of events captured with TraceEvent (ClockCycles issue): (11 Items)
Hi all,
is it possible at all to synchronize events captured with TraceEvent across cpus?
The issue here is that in the trace buffers the events coming from different cpus
have a timestamp that is apparently generated with ClockCycles(), whose counters are not synchronized.
How can I properly calculate time intervals in this situation?
Thank you,
Claudio
Re: cross-cpu synchronization of events captured with TraceEvent (ClockCycles issue)
ClockCycles() is assumed to be synchronized across cores (in theory it
doesn't have to be, but there are various things that would break if
that assumption doesn't hold).
What board and BSP are you using?
--Elad
On Thu, 2018-05-17 at 02:46 -0400, Claudio Fontana wrote:
> Hi all,
> across cpus?
> different cpus
> Thank you,
> Claudio
> http://community.qnx.com/sf/go/post118821
> To cancel your subscription to this discussion, please e-mail ostech-
> core_os-unsubscribe@community.qnx.com
> --Elad
Hello Elad,
thank you for your answer,
I assumed ClockCycles counters were not synchronized between cores due to the documentation at:
http://www.qnx.com/developers/docs/7.0.0/#com.qnx.doc.neutrino.lib_ref/topic/c/clockcycles.html
But if they are always synchronized that solves my issue..
I am using an AArch64-based board (Renesas Car-M3 Starter Kit Pro) with the QNX bsp package from the Software Center.
As odd as it may sound, both the documentation and what I said are
correct ;-)
In *principle* it is true that the ClockCycle() callout (implemented
for each BSP separately) does not have to return a synchronized value.
In *practice* all aarch64 BSPs I know of will use a single clock
source. x86_64 BSPs use the rdtsc call which, again, is not guaranteed
to be synchronized in principle but seems to be in practice (at least
on the boards we tested, and that's quite a few).
There are certain features in 7.0 (specifically HRTs) that will not
function properly if ClockCycles() does not return a synchronized
value.
The bottom line is that you should not observe a problem with combining
traces from different cores in any of the official BSPs. If you do,
please let me know.
--Elad
> > it
> > if
> > --Elad
> Hello Elad,
> http://community.qnx.com/sf/go/post118826
thank you very much for your clarification, super-helpful!
Ciao,
Claudio
RE: cross-cpu synchronization of events captured with TraceEvent (ClockCycles issue)
If you want to be on the safe side you can verify this in the syspage.
https://www.qnx.com/developers/docs/7.0.0/com.qnx.doc.neutrino.building/topic/syspage/qtime.html
qtime->flags&QTIME_FLAG_GLOBAL_CLOCKCYCLES
cheers
Sent: Friday, May 18, 2018 3:33 PM
To: ostech-core_os@community.qnx.com
Subject: Re: cross-cpu synchronization of events captured with TraceEvent (ClockCycles issue)
correct ;-)
value.
please let me know.
--Elad
> > it
> > if
> > --Elad
> Hello Elad,
OSTech
http://community.qnx.com/sf/go/post118827
Re: RE: cross-cpu synchronization of events captured with TraceEvent (ClockCycles issue)
> syspage/qtime.html
> cheers
Thank you John,
I checked the value of qtime->flags, and it is 0x3.
Should I conclude that ClockCycle is not synchronized across cores?
#define QTIME_FLAG_TIMER_ON_CPU0                0x00000001u
#define QTIME_FLAG_CHECK_STABLE                 0x00000002u
#define QTIME_FLAG_TICKLESS                             0x00000004u
#define QTIME_FLAG_GLOBAL_CLOCKCYCLES   0x00000008u
What is QTIME_FLAG_TIMER_ON_CPU0, does it help my case?
Thank you again,
Claudio
I don't think that the QTIME_FLAG_GLOBAL_CLOCKCYCLES flag is actually
set by any BSP, which doesn't mean that the value of ClockCycles() is
not synchronized.
What board are you using?
--Elad
> > syspage.
> > ding/topic/
> > syspage/qtime.html
> > cheers
> Thank you John,
> Thank you again,
> Claudio
> http://community.qnx.com/sf/go/post118844
> not synchronized.
> --Elad
Hi Elad,
Ciao,
Claudio
The implementation of ClockCycles() on aarch64 reads CNTVCT_EL0. As far
as I know reading this register should yield the same value regardless
of the core, so long as you don't use virtualization.
--Elad
> > actually
> > is
> > not synchronized.
> > --Elad
> Hi Elad,
> Ciao,
> Claudio
> http://community.qnx.com/sf/go/post118853
> --Elad
Thanks a lot Elad, I will proceed with this.
Regarding virtualization, it might be in scope for the future,
I should be fine anyway for what concerns VCPUs inside the same VM right?
To be more clear,
assuming we are running inside a VM, and we are using TraceEvent only inside this VM to track the VCPUs in this VM, the
EL2 Counter offset should be identical right?
Thanks a lot,
Claudio
