Forum Topic - [QNX7] pci_device_read_* segfaults, then hangs: (4 Items)
I am familiarising myself with the new pci-server of QNX7. That is why I wrote a tiny example tool that enumerates all
PCI devices and reads the device ID, as follows:
#include <stdio.h>
#include <pci/pci.h>
#include <pci/cap_pcie.h>
int main() {
  uint_t idx = 0;
  pci_bdf_t bdf;
  while ((bdf = pci_device_find(idx, PCI_VID_ANY, PCI_DID_ANY, PCI_CCODE_ANY)) != PCI_BDF_NONE)
      /* get next device instance */
      printf("Found device %d\n", idx);
      pci_err_t err;
      pci_did_t did;
      err = pci_device_read_did(bdf, &did);
      ++idx;
  printf("Exited main\n");
  return 0;
The problem is that this program segfaults when I run it, here's the telnet output:
# /tmp/qnx7test_c
Found device 0
Process 213017 (qnx7test_c) terminated SIGSEGV code=4 fltno=2 ip=b822afa7(/lib/dll/pci/pci_hw-Intel_x86.so@hwmod_init+
0x00000207) mapaddr=00005fa7.
Memory fault (core dumped)
The "pci_device_read_did" command caused the segfault. When I run the program again, it simply blocks at the exact same
place (no segfault anymore though!).
I am completely stumped, I have no idea what the problem could be.
Can anyone help me?
Best regards,
Benjamin
Re: [QNX7] pci_device_read_* segfaults, then hangs
SIGSEGV/4/2 is a general protection fault. You are probably reading
from the wrong address.
--Elad
On Thu, 2018-01-25 at 09:21 -0500, Benjamin Richner wrote:
> Hello,
> why I wrote a tiny example tool that enumerates all PCI devices and
> #include <stdio.h>
> int main() {
>   uint_t idx = 0;
>   pci_bdf_t bdf;
>       pci_err_t err;
>       pci_did_t did;
>       ++idx;
>   return 0;
> telnet output:
> # /tmp/qnx7test_c
> Found device 0
> ip=b822afa7(/lib/dll/pci/pci_hw-Intel_x86.so@hwmod_init+0x00000207)
> mapaddr=00005fa7.
> program again, it simply blocks at the exact same place (no segfault
> anymore though!).
> Can anyone help me?
> Best regards,
> Benjamin
> http://community.qnx.com/sf/go/post118465
> To cancel your subscription to this discussion, please e-mail ostech-
> core_os-unsubscribe@community.qnx.com
Thank you for you reply, Elad Lahav.
So, how can it happen I'm reading from the wrong address? bdf is a direct, valid result from pci_device_find. The
library pci_hw-Intel_x86.so exists and is at the specified path. All I'm doing is use pci_device_read_did. I have no
influence over what kinds of reads this function does - that's closed source QNX code.
So I'm afraid I still do not understand how to fix this.
I found it out. My program first had to gain the rights to do PCI IO, using the line
ThreadCtl(_NTO_TCTL_IO, 0);
That was it. It's no longer segfaulting. *facepalm*
However, I do think it's weird that an application that does not do this can lock up the entire pci server. I consider
that a bug.
