Forum Topic - system() Surprise of expectation: (4 Items)
There is a simple code:
#include <stdio.h>
#include <stdlib.h>
Int main (int argc, char * argv [])
   Int ret;
  ret = system ("uname -a"); // any sh command
system () function is executed without an error,
The output of the command "uname -a" is correct, and ret = 0;
Now twu controllers A1 and A2 in the Qnet network, and on the remote controller A2
there is a file / net / A2 / tmp / tmpfile.
#include <stdio.h>
#include <stdlib.h>
   Int ret, fp;
   fp = open ("/ net / A2 / tmp / tmpfile", O_RDWR);
When the program is executed on the A1 controller and when the remote file is successfully opened,
So that fp> 0, the system ("uname -a") function fails with an error, "sh: can not fork, try again" is output.
The error code is ret = 256, "Socket is already connected".
How can I explain the failure of system () to call sh and execute the command when the file on the remote controller is
open?
Thank you.
Re: system() Surprise of expectation
> #include <stdio.h>
> #include <stdlib.h>
>    Int ret;
> Now two controllers A1 and A2 in the Qnet network, and on the remote
> controller A2
> #include <stdio.h>
> #include <stdlib.h>
>    Int ret, fp;
> when the file on the remote controller is open?
> Thank you.
Hello Leonid,
please tell us what QNX version you are using (6.5, 6.6 or 7.0), and what processors machines A1 and A2 have (presume
both are x86 but please tell).
Albrecht
What if you change the open from O_RDWR to 'O_RDWR | O_CLOEXEC'.  My guess
is that the fork is failing to dup the fds you have open.
>> #include <stdio.h>
>> #include <stdlib.h>
>>    Int ret;
>> controller A2
>> #include <stdio.h>
>> #include <stdlib.h>
>>    Int ret, fp;
>>file is
>>"sh: can
>>command
>> Thank you.
