Forum Topic - Periodically sleeping the system for an arbitrary amount of time: (3 Items)
I am looking into the possibility of using QNX for a project. I want to design a system that is able to sleep for an
arbitrary but configurable amount of time and then wake up for a different but configurable amount of time.
The precision of the sleeping/wake up time is not relevant here.
For instance, sleeping for 800ms (+ or -) and waking up for 200 ms. This way, the system can save a lot of battery.
Is this feasible using QNX? If yes, can you give me some hints? If not, thanks anyway :)
Re: Periodically sleeping the system for an arbitrary amount of time
Hi Martin,
Of course QNX (an a lot of other OS including Linux and some the minimal ones) are able
to performs such task.
I suppose that what You really want is to stay in suspend/low power mode for an amount
of time  and ther resume activity for another  amount of  time , so You must  be sure that
Your target CPU and pheriperals will be designed to suport low power AND that QNX
supports that hardware. See the power management for QNX details.
regards,
Mario
Hi Mario
I have been looking into something similar, and I have been having a problem finding relevant docs for 6.6
May I ask if you could post which doc could be used as a reference?
Much appreicated.
