Forum Topic - How to work with MSI in x86 target, QNX 6.5.0SP1: (4 Items)
Hi, I have a x86 board with 2 PCIe cards. I am able to boot QNX 6.5.0SP1 from a USB drive on the target. I booted with
startup-apic & pci-bios-v2 is running on the board.
Now my question is
1) How do i know whether MSI is enabled or not?
2) How to find out Device & vendor ID for MSI?
3) How to get MSI interrupts working?
Please let me know.
Manas
Re: How to work with MSI in x86 target, QNX 6.5.0SP1
Hi Manas,
I've added some answers inline.
By the way are you aware of our new PCI framework here -
http://community.qnx.com/sf/frs/do/viewRelease/projects.bsp/frs.updated_pci
e_framework_for_qnx_s.qnx_sdp_6_6_pcie_server_archive? The old
"pci-bios-v2" will no longer be used in future products and plus the new
PCI server has much better support for MSI and MSI-X, cleaner APIs, and
several new features. If possible I'd suggest using the new PCI server.
>from a USB drive on the target. I booted with startup-apic & pci-bios-v2
>Now my question is
[Mark] - With the old PCI server (pci-bios-v2) if the server detects that
the device supports MSI's they get enabled automatically. There is a flag
(PCI_USE_MSI) which requests that MSIs be enabled but even if the flag
isn't specified we enable MSIs anyway (IF the device supports MSIs).
[Mark] You can use the "pci" utility with verbosity...pci -vvvvv
[Mark] - You could attach to the interrupt returned by the PCI server and
seeing if your driver is working as expected.
The link mentioned here is not found
The page you requested cannot be found.
If you feel you have received this message in error, please contact the TeamForge administrator.
The link is broken across two lines...
"http://community.qnx.com/sf/frs/do/viewRelease/projects.bsp/frs.updated_pcie_framework_for_qnx_s.
qnx_sdp_6_6_pcie_server_archive"
Try 'BSP Directory", then "Experimental Drivers and Utilitiles" ff the link doesn't work.
