Forum Topic - Regarding the raising edge interrupt for GPIO in iMX6DQ: (6 Items)
Hi All,
I am trying to use the interrupt option in iMX6DQ for GPIO.I am using the QNX 6.6 . The interrupt API i am using for
registering is interrupt_attach() with _NTO_INTR_CLASS_EXTERNAL as the flag.
I am using the edge trigger interrupts ,as if i configure the level triggered interrupt the system is going for a reset
the moment the interrupt is attached. Whatever edge i am configuring to the GPIO raising edge or the falling egde i am
always getting the falling edge interrupt.
Has anybody worked on this and have been able to get the raising edge interrupt?
Kindly help i having trying to read the configurations also what ever is configured for the port for the interrupt ,
there i am able to check the configurations as i configured.
Thanks in advance for your help
Re: Regarding the raising edge interrupt for GPIO in iMX6DQ
Adding to the above query i have a point to say that the interrupt is working for the falling edge and not working for
raising edge alone.
I am attaching a sample code used for configuration of interrupt
Attachment: Text GPIO_intr_conf.txt 7.39 KB
Hi Praveen,
Can you try using the attached sample apps?
The mx6gpio utility can be used to configure a GPIO, e.g.
# Configure GPIO1[0] as an input with high-level sensitivity
mx6gpio -i -b1 -p0 -s1
You can then use the irqtest utility to attach to the corresponding IRQ -
in the example above that would be IRQ 160 (decimal).
Mark
Attachment: Text sample_code.tar.gz 5.16 KB
Hi Mark,
Thank you very much for your response. I have taken the code and have checked it. I was able to check the interrupts but
 what is happenning is that if i configure the edge interrupt either rising edge or the falling edge the interrupt is
occurring in both the conditions.
Like if i had configured the raising edge i am getting the interrupt in both the rising and the falling edge of the pin.
 It is the same when configuring for the falling edge.
Is it the same condition you are also facing in your test result. In my code i am using the interrupt_attach() API and
doing a configuration to mask register .
Hi Praveen,
Could you check the GPIOx_EDGE_SEL register? Also I'm curious how you're
triggering the interrupt? You could hook up a scope and confirm that the
source that is driving this signal is acting as expected.
I can't say I've seen this behaviour before but I haven't really tested
rising/falling edge GPIO IRQs on mx6 in detail.
Mark
Hi Mark,
Sorry for so delayed response. I had checked the value of the EDGE_SEL_REG and also the pin status with scope.The pin is
 active low by default and on button press it goes to high state. The edge select register value is 0 wiht the default
value.
