Forum Topic - Wrong time zone: (2 Items)
Wrong time zone
Hi all,
I am currently evaluating x86_AnM. One thing I found out that the time zone is set to America instead of NZ. I have
tried, ntpd -d as well as ntpdate and check with date, but the date and time is time using US time.
Can you someone help, please?
Thank you
Siow-LIm
Re: Wrong time zone
You usually set the clock on your system to UTC, and then use the TZ environment variable to set the time zone. If TZ
isn't set, the system uses the default time zone, which is Eastern time. See http://www.qnx.com/developers/docs/am11/
topic/com.qnx.doc.neutrino.user_guide/topic/environment_TimeZone.html?cp=1_0_13_6_5 in the online documentation.
