Forum Topic - Linking to QNX Qt libraries such as QtQnxCar2, QPps in a project: (3 Items)
Would anyone know how to include/use the QNX Qt libraries such as QtQnxCar2, QPPS, QPlayer in a Qt project? I think this
 involves including a package in Qt or may be linking the library in the .pro file, just can't figure out what it is
though.
QNX has lot of documentation about the libraries, but nothing about how to actually include and use them in a Qt project
I am specifically looking for how to use the Qpps namespace in my project. For example, I've linked the qpps library as
below in my .pro file:
LIBS += -L$PWD/../../../../../home/me/qnx660/target/qnx6/armle-v7/qtcar/lib/ -lqpps
INCLUDEPATH += $PWD/../../../../../home/me/qnx660/target/qnx6/armle-v7/qtcar
DEPENDPATH += $PWD/../../../../../home/me/qnx660/target/qnx6/armle-v7/qtcar
But my project still doesn't recognize anything related to qpps.
Toolchain:
Qt Creator 3.3.2
Qt 5.2.0
QNX Car 2.1
QNX SDP 6.6
Ubuntu 14.04
Re: Linking to QNX Qt libraries such as QtQnxCar2, QPps in a project
Looking at an application that uses qpps - in the .pro file
INCLUDEPATH += qpps
DEPENDPATH += qpps
LIBS += -Lqpps/lib -lqpps
...then in each .cpp file
using namespace QPps;
Thanks Dennis. I tried that, and get this build error:
cc1plus: warning: command line option '-std=gnu1x' is valid for C/ObjC but not for C++ [enabled by default]
mainwindow.cpp:5:17: error: 'QPps' is not a namespace-name
mainwindow.cpp:5:21: error: expected namespace-name before ';' token
cc: /home/patel/qnx660/host/linux/x86/usr/lib/gcc/arm-unknown-nto-qnx6.6.0eabi/4.7.3/cc1plus error 1
make: *** [mainwindow.o] Error 1
17:04:20: The process "/home/patel/qnx660/host/linux/x86/usr/bin/make" exited with code 2.
I guess my path may not be right or some environment variable not set. Would you know why it can't find the lib qpps?
I tried the code below as well (by explicitly specifying lib location), but same error.
LIBS += -L$$PWD/../../../../../home/patel/qnx660/target/qnx6/armle-v7/qtcar/lib/ -lqpps
INCLUDEPATH += $$PWD/../../../../../home/patel/qnx660/target/qnx6/armle-v7/qtcar
DEPENDPATH += $$PWD/../../../../../home/patel/qnx660/target/qnx6/armle-v7/qtcar
> INCLUDEPATH += qpps
> DEPENDPATH += qpps
