Forum Topic - Blocking on QNX IPC and FD: (2 Items)
Hello all,
Is their a mechanism to have a thread block on PPS file descriptors and QNX IPC ( Message/Pulses )? My thread is not a
resource manager.
I tried using dispatch library mechanism.
dispatch_create
select_attach
pulse_attach
dipatch_context_alloc
message_connect
dispatch_block
dispatch_handler
dispatch_block does not unblock with pulses. I am sending pulses to coid returned by message_connect using MsgSendPulse.
Sesh
Re: Blocking on QNX IPC and FD
Below issue has been resolved. Root cause was related to timing issue. Overall the library works great to receive pulses
, fd data, ipc messages through one single blocking API.
> Hello all,
> IPC ( Message/Pulses )? My thread is not a resource manager.
> dispatch_create
> select_attach
> pulse_attach
> message_connect
> dispatch_block
> dispatch_handler
> Regards,
> Sesh
