Forum Topic - UART read/write: (3 Items)
UART read/write
hi,
i am using sabrelite board, and right now i developed the UART driver hal code and following are the working results,
i.e.
data handling method:
for read and write i am using DMA mode. and i created thread for transmit as well as receive,
transmit/receive handle i am checking the data size if it is 0 then i am sending the sem_post,
so that in read/write sem_wait will reales.
TEST Procedures,
1)very first time i am able to read the data from the teraterm
2)i try to write the data to teraterm,
3)again i try to read the data from teraterm, but this time i am not able to read it?
so anyone faced this kind of problem, kindly help me to solve this issue.
With Regards
Maddy
Re: UART read/write
Just curious.  Why wouldn't you use the driver supplied with the BSP?
Re: UART read/write
our requirement is to develop the HAL library (avoid the Resource manager)
and  use DMA method.
