Forum Topic - Unable to install QNX Momentics Tool Suite 6.5 on Scientific Linux 6.4: (1 Item)
Dear Sir/Madam,
I am unable to install  QNX Momentics Tool Suite 6.5 on Scientific Linux
6.4.
While installation using "qnx_setup_linux.jar" --> it gives the following
error after entering License key
"java.lang.UnsatisfiedLinkError : no qnxlic in java.library.path"
Please Note that I have already disabled selinux on my system. After that
also I am getting the same error.
I am using Java run time version 1.7.0 for installation using the following
command
> /usr/lib/jvm/jre1.7/bin/java -cp qnx_setup_linux.jar run
While directly installing using qnxsdp-6.5.0-nnnnnnnn-linux.bin it was
exiting after displaying "Installing Java Virtual Machine." message on
command line.
Kindly suggest if any additional configuration changes has to be done in
order to install QNX Momentics IDE on Scientific Linux 6.4.
Kindly help and guide in this regard.
Thank you.
Preetha M. Nair,
Scientific Officer (F),
Electronics Division,
B.A.R.C.
Attachment: HTML sf-attachment-mime20866 7.79 KB
