Forum Topic - USB support without using diskboot: (6 Items)
I have attached a build file where diskboot is not used in order to speed the boot process.  However, I can not get a
USB mass storage device (stick) to show up under /fs as it does with the qnxbasedma (default)one.  It appears that umass
-enum is missing something it needs to start devb-umass and mount the drive.
With the qnxbasedma one, I get a message in the system log when I plug in and when I unplug, but not with the attached
one.  Also the devb-umass is not started when I plug in the stick as it is with qnxbasedma.  I am hoping this is just
something simple, but documentation is hard to come by.  Does anyone know what magic line(s) I am missing in the build
file.
Tim
Attachment: Text fastdiskboot_testu4.build 2.23 KB
RE: USB support without using diskboot
This is a guess, but should you specify something under /dev for the -d
option to umass-enum? You've specified:
  -d /dev
but the default is:
  -d /dev/umass
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Re: USB (actually umass-enum) support without using diskboot
Hi folks,
I am having this exact problem, and I didn't see any resolution for the original poster. umass-enum is being started
with the same arguments used in the default OS image, but it won't work. I put a -v on its command line, and the problem
 it is having is errno 2 (No such file or directory) trying to start devb-umass. devb-umass is in /proc/boot, and can be
 started from the shell prompt. If I put umass-enum in rc.local, it works fine.
Can anyone suggest what I need to do to the build file to get umass-enum to work from the image?
Ned
This is merely speculation, but you should be able to create a script in the
build file and call that script from the startup script section. It's a bit
of an ugly hack, but it might work.
Cheers,
-Aaron
On Monday 29 September 2008 21:31:11 Ned Snow wrote:
> Hi folks,
> original poster. umass-enum is being started with the same arguments used
> and the problem it is having is errno 2 (No such file or directory) trying
> to start devb-umass. devb-umass is in /proc/boot, and can be started from
> Thanks,
> Ned
> http://community.qnx.com/sf/go/post14211
Re: USB support without using diskboot
hi tim,
did you find a solution for this problem?
i'm having exactly the same problem, but i can't figure out how to solve it.
as i want to boot from network (NFS) diskboot is somewhat redundant. i do however start /etc/system/sysinit in order to
get to run the enumerators and the system initialization, which is supposed to work without diskboot, but obviously
doesn't.
best regards
phil
I forgot to mention that in my case it's a general problem with the USB stack. If I take a diskboot QNX image the USB
stack is being executed. If I however boot without diskboot first the USB stack is NOT executed although the enumeration
 process should do this and secondly if I'm starting it manually it doesn't work at all.
