Forum Topic - Create named shared memory at destinated physical address: (2 Items)
When I tried to create named shared memory at destinated physical address using shm_open(), shm_ctl_special() and mmap()
 as below code, it doesn't work. The returned address from mmap always point to 0x80100000 and this address can't be
written to.
Please help to see why it doesn’t work.
#define SharedName "SHARED_MEMORY_C5"
#define ARM_PTE_V6_SP_TEX_MASK_CACHED    ARM_PTE_V6_SP_TEX(5)
#define ARM_PTE_V6_SP_TEX_MASK_NONCACHED ARM_PTE_V6_SP_TEX(1)
#define PTE_CACHED_SPECIAL_BITS \
	(ARM_PTE_V6_SP_TEX_MASK_CACHED | ARM_PTE_CB | ARM_PTE_V6_SP_XN)
#define PTE_NONCACHED_SPECIAL_BITS \
    (ARM_PTE_V6_S | ARM_PTE_V6_SP_TEX_MASK_NONCACHED | ARM_PTE_V6_SP_XN)
      size_t size = 0x800000;
      unsigned int PhyAddr = 0xc5000000;
	int                     fd;
    char *pDstAddr;
    fd = shm_open(SharedName , O_CREAT | O_TRUNC | O_EXCL | O_RDWR,
        0666);
    shm_unlink(SharedName );
    shm_ctl_special(fd, SHMCTL_PHYS,
       PhyAddr, size, PTE_CACHED_SPECIAL_BITS);
    pDstAddr = (char*)mmap(NULL, size,
        (PROT_READ | PROT_WRITE), MAP_SHARED,
        fd, (off_t)0 + PhyAddr);
    printf( "That means: %s\n", strerror( errno ) );
      *pDstAddr = 0x55;
      return EXIT_SUCCESS;
Re: Create named shared memory at destinated physical address
The offset parameter to mmap should be zero in this case.
Colin
Sent from my BlackBerry 10 smartphone on the Rogers network.
Sent: Friday, August 16, 2013 4:25 AM
To: ostech-core_os
Reply To: ostech-core_os@community.qnx.com
Subject: Create named shared memory at destinated physical address
written to.
        int                     fd;
    char *pDstAddr;
        0666);
      *pDstAddr = 0x55;
OSTech
http://community.qnx.com/sf/go/post104247
Attachment: HTML sf-attachment-mime16586 4.96 KB
