Forum Topic - QDB server & database not found: (5 Items)
i have read about the qdb server under the help section and i have no clue on how to interact with it. Also when i use
qdb_connect() to connect to the database, it replied with a "No such path or directory".
please advise.
Jian Rong
Re: QDB server & database not found
Read through the "Starting QDB" section of the documentation here:
http://www.qnx.com/developers/docs/6.5.0_sp1/topic/com.qnx.doc.qdb_en_dev_g
uide/starting.html?cp=2_0_2
This will help you to start the qdb server.  When this is running you will
see your configured databases in /dev/qdb/ (use "ls /dev/qdb/" to see).
If you do not see /dev/qdb/ please confirm that qdb started successfully;
if you do not see your database name listed please confirm that it is
properly configured (start qdb with "-vvvvv" and check "sloginfo" for an
error messages).
If qdb is running you can use the qdb_*() APIs in an application to
interact with qdb; you can also use the command-line utility "qdbc".  Qdbc
is primarily used to run SQL statements on your database:
uide/qdbc.html?cp=2_0_3
Ryan J. Allen
QNX Software Systems
On 13-05-19 9:08 PM, "Jian Rong Yong" <community-noreply@qnx.com> wrote:
>Hi,
>clue on how to interact with it. Also when i use qdb_connect() to connect
>please advise.
>Thanks,
>Jian Rong
The reference example not real specific, but you need create file /db/customerdb.cfg as the text between dashes-
[customerdb]
Filename=/db/customerdb
Schema File=/db/customerdb.sql
/db/customerdb.sql:
CREATE TABLE customers(
   custoemrid INTEGER PRIMARY KEY AUTOINCREMENT,
   firstname TEXT,
   lastname TEXT
Then start qdb as...
# qdb -c /db/qdb.cfg -vvvvvv -otempstore=/tmp -Rauto -A
If it succeeds, you should see...
QDB: created missing database customerdb
and /dev/qdb/customerdb will exist.
i tried starting qdb following the instruction under the help section but it replies me with a "Idd:FATAL: Could not
load library libsqlite3.so.1".  Any advise on how to fix this error?
Jian Rong
RE: QDB server & database not found
It's looking for libsqlite3.so.1 in your LD_LIBRARY_PATH .  On my QNX650 HOST for some reason it is not in the /usr/lib
directory...but you can find it in QNX_TARGET.
thor$ uname -a
QNX thor 6.5.0 2010/07/09-14:44:03EDT x86pc x86
thor$ which qdb
/usr/sbin/qdb
thor$ objdump -x /usr/sbin/qdb | grep NEEDED
  NEEDED               libsqlite3.so.1
  NEEDED               libz.so.2
  NEEDED               libc.so.3
thor$ which -sa libsqlite3.so.1
which: no libsqlite3.so.1 in :/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib:/usr/photon/lib:/usr/photon/dll:/usr/local/lib:
/opt/X11R6/lib:/usr/X11R6/lib:/proc/boot
thor$ qdb
ldd:FATAL: Could not load library libsqlite3.so.1
thor$ find /usr -name "libsql*"
/usr/qnx650/target/qnx6/ppcbe-spe/usr/lib/libsqlite3.so
/usr/qnx650/target/qnx6/ppcbe-spe/usr/lib/libsqlite3.so.1
/usr/qnx650/target/qnx6/ppcbe/usr/lib/libsqlite3.so
/usr/qnx650/target/qnx6/ppcbe/usr/lib/libsqlite3.so.1
/usr/qnx650/target/qnx6/x86/usr/lib/libsqlite3.so
/usr/qnx650/target/qnx6/x86/usr/lib/libsqlite3.so.1
/usr/qnx650/target/qnx6/armle-v7/usr/lib/libsqlite3.so
/usr/qnx650/target/qnx6/armle-v7/usr/lib/libsqlite3.so.1
/usr/qnx650/target/qnx6/armle/usr/lib/libsqlite3.so
/usr/qnx650/target/qnx6/armle/usr/lib/libsqlite3.so.1
/usr/qnx650/target/qnx6/shle/usr/lib/libsqlite3.so
/usr/qnx650/target/qnx6/shle/usr/lib/libsqlite3.so.1
thor$ ls -l */usr/lib/libsqlite3.so*
ls: No such file or directory (*/usr/lib/libsqlite3.so*)
thor$ use -i /usr/qnx650/target/qnx6/x86/usr/lib/libsqlite3.so.1
NAME=libsqlite3.so
DESCRIPTION=SQLite Library
DATE=2010/07/09-13:23:07-EDT
STATE=stable
HOST=mainbuild
USER=builder
VERSION=6.5.0
TAGID=89
thor$ echo $QNX_TARGET
thor$ echo $LD_LIBRARY_PATH
:/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib:/usr/photon/lib:/usr/photon/dll:/usr/local/lib:/opt/X11R6/lib:/usr/X11R6/lib
ib:/opt/X11R6/lib:/usr/X11R6/lib:/usr/qnx650/target/qnx6/usr/lib:/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib
thor$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/qnx650/target/qnx6/x86/usr/lib
thor$ qdb
qdb: must be superuser to start server
From: Jian Rong Yong [mailto:community-noreply@qnx.com]
Sent: May-26-13 9:49 PM
To: ostech-core_os
Subject: Re: QDB server & database not found
Jian Rong
OSTech
http://community.qnx.com/sf/go/post101698
