Forum Topic - iofunc functions: (6 Items)
iofunc functions
In Getting Started with QNX Neutrino, Rob Krten refers to a couple of iofunc functions that I couldn't find in the
source:
  iofunc_close_default()
  iofunc_read()
Do these functions actually exist?
The book also refers to resmgr_start(), which is defined in <sys/resmgr_compat.h>, but isn't documented. Should it be?
Thanks.
Re: iofunc functions
> iofunc functions that I couldn't find in the source:
This one doesn't exists - there is iofunc_close_ocb_default() and iofunc_close_dup_default()
>   iofunc_read()
Can't find this one anywhere.  There is an iofunc_read_default() though...
The compat stuff is only for people who wrote a resmgr back before we switched
to the dispatch callout interface.  Was resmgr_start() not documented back then? :-)
> Thanks.
> http://community.qnx.com/sf/go/post6236
cburgess@qnx.com
>   iofunc_read()
I can't find those in the source either.
But in lib/c/public/sys/iofunc.h there is an iofunc_read_default(). There
are also two closes:
iofunc_close_ocb_default() and iofunc_close_dup_default().
I suspect "iofunc_cread()" is a typo. Perhaps someone knows the history of
the iofunc_*close*_default() functions.
-ad
iofunc_read() is listed in the doc page for io_read() as a helper function, along
with iofunc_read_verify()
iofunc_close_default() is listed as a helper for io_close_ocb(), so I think
it was a typo, and should be listed as iofunc_close_ocb_default()
>  >   iofunc_read()
> -ad
> http://community.qnx.com/sf/go/post6239
cburgess@qnx.com
I've created a doc PR. I'll correct the reference to iofunc_close_ocb_default(), and it sounds like I should just remove
 the one to iofunc_read().
Here's what the book says about resmgr_start():
The control structure (type resmgr_attr_t) is passed to the resmgr_start() function, which looks at the various members
and handles the main receive loop of the resource manager.
Should I change it to something like this?
The control structure (type resmgr_attr_t) is passed to the resmgr_attach() function, which puts the resource manager's
path into the general pathname space and binds requests on this path to a dispatch handle.
(The book already discusses the dispatch interface, and there are no other references to resmgr_start()).
Thanks for your help.
> >   iofunc_read()
Should be iofunc_read_default() (assuming I have the correct context) and
there
are two close functions deliberately, and with very different
functionalities.  The
one most people are interested in is iofunc_close_ocb_default().
Hope this helps,
 Thomas
