Forum Topic - QNX Messages threadsafe?: (2 Items)
I have a MessageHandler() function for a process to handle incoming QNX messages, that will immediately respond to any
messages sent with a MsgReply(), then actually pull the data out and process the message. I'm using this to make a QNX
message similar to an asynchronous pulse, but able to send an arbitrary amount of data. I understand that message data
is copied between process address spaces, and the message itself should hang around for the scope of the
MessageHandler() function. If I then received another message before I finished processing the first one could I run
into problems with the second message getting copied over the memory of the first one?
Here's an example:
void MessageHandler(void *Msg, int Type, int ReceiveID)
   MsgReply(ReceiveID, EOK, NULL, 0); // reply immediately
   MyMsgType *foo = (MyMsgType*)Msg;
   int a = foo->GetAValue();
   // if I do more stuff here, foo pointer should still be valid for the
   // scope of this function, but if I immediately get another message
   // will Msg (and foo) get overwritten?
Re: QNX Messages threadsafe?
> messages, that will immediately respond to any messages sent with a MsgReply()
> make a QNX message similar to an asynchronous pulse, but able to send an
> arbitrary amount of data. I understand that message data is copied between
> scope of the MessageHandler() function. If I then received another message
> before I finished processing the first one could I run into problems with the
> Here's an example:
Not until you a the MsgReceive.  If that is a problem in your design, just pass MsgReceive a different pointer, a
circular queue type of design.
By the way have you looked at the async_ stuff which are ok as long as you don't need networking.
