Forum Topic - Call to read() returns EINVAL when it should be returning EAGAIN: (3 Items)
OS version 6.5.0 SP1
My application is reading from a serial port created using devc-serusb. The port is opened using the O_NONBLOCK flag.
The port (m_in) is polled every 10 ms with a call like -
uint8_t c = 0;
int32_t ret = read( m_in, &c, 1 );
When there is nothing to read ret is set to -1 and errno is set to EINVAL, whereas according to the documentation it
should be set to EAGAIN. When there is data available to be read, ret is set to 1 and c contains the received byte,
which is correct.
I cannot just ignore the errno because I need to detect a failure caused by the user unplugging the USB cable.
Is this a bug, or am I missing something?
RE: Call to read() returns EINVAL when it should be returning EAGAIN
Hi Jim,
This is likely not the best forum for this hardware related question; core OS is more like scheduling algorithms or IPC
mechanisms.
You would be more likely to get a relevant reply either via a hardware-related forum or, if you have one, via your
formal support interface.
From: Jim Douglas [mailto:community-noreply@qnx.com]
Sent: Wednesday, January 30, 2013 5:58 PM
To: ostech-core_os
Subject: Call to read() returns EINVAL when it should be returning EAGAIN
uint8_t c = 0;
which is correct.
OSTech
http://community.qnx.com/sf/go/post98886
Re: Call to read() returns EINVAL when it should be returning EAGAIN
I tried this and it worked as expected - both on ser1 and and serusb1.  read() returned -1 with errno as  EAGAIN.
