Forum Topic - Device register mapping in ARM: (3 Items)
we are using AT91SAM9263 on QNX 6.4.1. As per QNX documentation 'mmap_device_io()' should be called only with io
privileges. i.e)calling thread should have called ThreadCtl() with the _NTO_TCTL_IO before using mmap_device_io().
I got following code to toggle gpio port. I am able to run this code successful without io privilege.
fyi, I am running this code as 'root'.
#include <stdlib.h>
#include <stdio.h>
#include <stdint.h>
#include <sys/mman.h>
#include <arm/at91sam9263.h>
#include <sys/types.h>
#include <hw/inout.h>
	volatile uintptr_t	gpio_hw_vbase = (uintptr_t)MAP_FAILED;
	gpio_hw_vbase = mmap_device_io((size_t)(5u * (uint_t)AT91SAM9263_PIO_SIZE), (uint64_t)AT91SAM9263_PIOA_BASE);
	if(gpio_hw_vbase == MAP_FAILED)
		printf("map failed, no io privilege");
	else
		printf("map success, io privilege granted");
		out32( (uintptr_t)(gpio_hw_vbase + ((uintptr_t)2*(uintptr_t)AT91SAM9263_PIO_SIZE) + AT91SAM9263_PIO_SODR),
(uint32_t)0x00001000u );
		getchar();
		out32( (uintptr_t)(gpio_hw_vbase + ((uintptr_t)2*(uintptr_t)AT91SAM9263_PIO_SIZE) + AT91SAM9263_PIO_CODR),
	return EXIT_SUCCESS;
Re: Device register mapping in ARM
I'd also like to know the answer to this question.
i.e mmap_device_io appears to allow I/O access without I/O priveleges even though the documentation indicates ThreadCtl(
...) is required.
Is this an aspect of ARM memory mapped I/O and therefore only root permissions are required in order to do the mapping
in the first place, or is this an oversight in the documentation that should indicate this isn't strictly necessary for
ARM processors but should be coded thus for portability?
Memory mapped I/O doesn't require privileged mode, so _NTO_TCTL_IO is
essentially only required to manipulate the CPSR I bit to disable
interrupts.
	Sunil.
ThreadCtl(...) is required.
> http://community.qnx.com/sf/go/post92662
