Forum Topic - Kernel trace : dynamic filtering : event handler restrictions: (2 Items)
Hello QNX Developers,
As I understand from docs, I can attach event handling routine via  TraceEvent (_NTO_TRACE_ADDEVENTHANDLER, ...) and it
will be called by the kernel directly.
1) What are the stack restrictions ?
2) How much of process address space is mapped ?
    Can I affect it in any way ?
    Example code from QNX documentation accesses process global variable, so I assume that at least
    some part of process address space is mapped.
    In case of complete address space is mapped, then may be it makes
    sense to keep the size of the executable implementing dynamic kernel event filtering
    as small as possible...
Thank you!
Re: Kernel trace : dynamic filtering : event handler restrictions
It's essentially the same as an interrupt handler - your entire address
space is mapped, but you are limited in stack usage
and can't make any kernel calls.
it will be called by the kernel directly.
> Thank you!
> http://community.qnx.com/sf/go/post91764
cburgess@qnx.com
