Forum Topic - IPC example code: (2 Items)
IPC example code
I am trying to do a quick prototype and need sample client server code.  I need to create a client and server that are
running in two differnt processes/programs.  I can not use mq or mqueue as the sever is linked aginst mqueue and client
is linked against mq!!!.  I was thinking of the quickest way to do is to use ChannelCreate(), ChannelAttach(), msgSend()
, msgReceive() premetives.  However, I am not sure how the client and the server find each other using the ChannelAttach
 and ChannelCreate phase.
I would appreciate it is someone can point me to a working code sample that I can use as a guide to write my client/
server.  Also, if these premetives are not the appropriate ones to use for the purpose I described above, please suggest
 an alternative.
RS.
Re: IPC example code
http://www.qnx.com/developers/docs/6.3.2/neutrino/prog/resmgr.html
On 11-10-12 12:29 PM, "Reza Salehi" <community-noreply@qnx.com> wrote:
>Hi,
>I need to create a client and server that are running in two differnt
>aginst mqueue and client is linked against mq!!!.  I was thinking of the
>quickest way to do is to use ChannelCreate(), ChannelAttach(), msgSend(),
>server find each other using the ChannelAttach and ChannelCreate phase.
>that I can use as a guide to write my client/server.  Also, if these
>described above, please suggest an alternative.
>Thanks,
>RS.
>OSTech
>http://community.qnx.com/sf/go/post89337
