Rohit Nair
09/28/2011 3:24 PM
post89124
I am seeing some weird behavior when I run ClockCycles tightly in a loop. ClockCycles should always return increasing
values, but sometimes it returns a value that's less than the previously returned value.
For example -
ThreadCtl(_NTO_TCTL_RUNMASK,(int*) 0x1);
perror(NULL);
start = ClockCycles();
while(1)
stop = ClockCycles();
if(start > stop)
diff = start - stop;
printf("??? start-%llu, stop-%llu,diff-%llu, iteration - %d\n",start,stop,diff,iter);
break;
start = stop;
iter++;
The iteration at which it happens is widely random. Ranging from 50 to 30000.
Could this be because of a wrong setup in init_qtime.c inside startup code ?
Andrew Sherk
Re: ClockCycles Misbehaving
Andrew Sherk
09/28/2011 3:27 PM
post89125
Are you running a SMP system (>1 CPU or core)? Pidin info output will
confirm.
Andy
On 11-09-28 3:24 PM, "Rohit Nair" <community-noreply@qnx.com> wrote:
>Hello,
>ClockCycles should always return increasing values, but sometimes it
>For example -
> perror(NULL);
> while(1)
> if(start > stop)
> break;
> start = stop;
> iter++;
>30000.
>code ?
>OSTech
>http://community.qnx.com/sf/go/post89124
Sunil Kittur(deleted)
09/28/2011 3:36 PM
post89126
What cpu/board is this running on?
Rohit Nair wrote:
> Hello,
> For example -
> perror(NULL);
> while(1)
> if(start > stop)
> break;
> start = stop;
> iter++;
Elena Laskavaia
Elena Laskavaia
09/28/2011 3:45 PM
post89127
Either you have 2 or more processors or it just simply wrapping (3 minutes wrapping time on mips)
On 09/28/2011 03:24 PM, Rohit Nair wrote:
> Hello,
> For example -
> perror(NULL);
> while(1)
> if(start > stop)
> break;
> start = stop;
> iter++;
Rohit Nair
Rohit Nair
09/28/2011 3:50 PM
post89128
But shouldn't the ThreadCtl call fix affinity to CPU0 ?
Andrew Sherk
Andrew Sherk
09/28/2011 4:12 PM
post89131
What is the return value of ThreadCtl() call? I wonder if it failed?
Does the strange behaviour persist when starting the process with on -C0
to fix to CPU0?
e.g.
# on -C0 ./testapp
Andy
>OSTech
>http://community.qnx.com/sf/go/post89128
Rohit Nair
Rohit Nair
09/28/2011 4:19 PM
post89132
ThreadCtl returns 0. The behavior persists even if I start with 'on -C0'.
> to fix to CPU0?
> e.g.
> # on -C0 ./testapp
> Andy
> >OSTech
Lichun Zhu
RE: ClockCycles Misbehaving
Lichun Zhu
09/28/2011 3:52 PM
post89129
It's already bind to the first CPU.
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 28, 2011 3:45 PM
To: ostech-core_os
Subject: Re: ClockCycles Misbehaving
> Hello,
> For example -
> perror(NULL);
> while(1)
> if(start > stop)
> break;
> start = stop;
> iter++;
OSTech
http://community.qnx.com/sf/go/post89127
Mario Charest
Mario Charest
09/28/2011 6:41 PM
post89136
Of What type are the variables start and stop?
> -----Message d'origine-----
> De : Rohit Nair [mailto:community-noreply@qnx.com]
> Envoyé : 28 septembre 2011 15:24
> À : ostech-core_os
> Objet : ClockCycles Misbehaving
> Hello,
> ClockCycles should always return increasing values, but sometimes it returns
> For example -
> perror(NULL);
> while(1)
> if(start > stop)
> break;
> start = stop;
> iter++;
> 30000.
Rohit Nair
Re: RE: ClockCycles Misbehaving
Rohit Nair
09/28/2011 7:23 PM
post89137
It's uint64_t.
> > À : ostech-core_os
> > Hello,
> > For example -
> > perror(NULL);
> > while(1)
> > if(start > stop)
> > break;
> > start = stop;
> > iter++;
> > 30000.
> > OSTech
Elena Laskavaia
Elena Laskavaia
09/28/2011 11:19 PM
post89140
So why do you think it is not wrapping around? (what cpu type is that?)
On 28/09/2011 7:23 PM, Rohit Nair wrote:
> It's uint64_t.
>>> À : ostech-core_os
>>> Hello,
>>> For example -
>>> perror(NULL);
>>> while(1)
>>> if(start> stop)
>>> break;
>>> start = stop;
>>> iter++;
>>> 30000.
>>> OSTech
> http://community.qnx.com/sf/go/post89137
Michael Tasche
Michael Tasche
09/29/2011 5:35 AM
post89145
if this is an ARM CPU, you perhaps have bug in the timer_value callout.
On ARM ClockCycles is emulated by the kernel.
We had the same issue on an at91sam6263 board in march 2010.
We fixed the callout and sent the patch to the support portal.
It was tracked under PR#75223.
-Michael
