Forum Topic - devc-ser8250 and slogger: (6 Items)
Hello.
In old QNX4 days, serial driver (dev.ser) logged an event in traceinfo system in case of framing, parity and other
errors.
It was very neat feature. Is there any equivalent in QNX 6.4 or newer?
I have tried starting devc-ser8250 with many "-v", but it only logged startup information about fifo sizes, buffer sizes
 to slogger.
Connecting serial line to other system with different baud rates produced garbage in qtalk screen, but sloginfo showed
no entries regarding serial line.
Have I forgotten something?
Thanks, PKY
Re: devc-ser8250 and slogger
It works for me on 6.5.0 x86:
# sloginfo
Apr 01 21:45:11    3     6     0 io-char: Framing error on /dev/ser2
Apr 01 21:48:49    3     6     0 io-char: S/W buffer Overrun error on /dev/ser2
I started devc-ser8250 with -F to disable flow control but nothing else that would matter.
Thanks for the info.
I have tried that, but it doesn't work for me. Could you please post cksum of devc-ser8250 you are using?
Mine is (in QNX 6.5.0 system) 1252698927 79459 /sbin/devc-ser8250
Do you have "special way to generate errors" or is your line generating them?
Thanks, PKY
> # sloginfo
> ser2
> would matter.
Update on my previous post.
My test setup: 2 computers, sending one configured to 38400 8N1, receiving one configured to 38400 8E1. Note the
difference in parity.
In QNX4 setup, after sending 196 bytes from xml file I get on receiving computer 120 framing errors and 80 parity errors
 logged in traceinfo.
In QNX6 setup, I get 19 framing errors and 14 parity errors. The difference in numbers (approx. only 1/6 is logged in
comparison to QNX4) may be the reason that so far I haven't seen any logs regarding these errors.
That made me suspicious about fifo threshold in qnx6 setup.
I made a test, when I configured rx fifo to 14, 4 and 1. (8 is the default setup)
Here are the results:
threshold 14 ... 12 framing errors, 11 parity errors
threshold 8 .... 19 framing errors, 12 parity errors
threshold 4 .... 39 framing errors, 13 parity errors
threshold 1 .... no errors ?????
It seems the higher the threshold, the less errors get reported. So to be able to check the line quality one should set
the threshold to 1. But unfortunately, no errors are reported at this setting.
Any ideas?
Regards, PKY
> # sloginfo
> ser2
> would matter.
# cksum `which devc-ser8250`
 476569156      80321 /sbin/devc-ser8250
# use -i `which devc-ser8250`
NAME=devc-ser8250
DESCRIPTION=Character device driver for the 8250 chipset
DATE=2010/07/09-13:55:14-EDT
STATE=stable
HOST=mainbuild
USER=builder
VERSION=6.5.0
TAGID=89
# uname -a
QNX localhost 6.5.0 2010/07/09-14:43:25EDT x86pc x86
The receiver was set to 57600 bits/s while the sender was set to 19200 bits/s, I believe. No application had the serial
port open at the time.
> computer 120 framing errors and 80 parity errors logged in traceinfo.
>  numbers (approx. only 1/6 is logged in comparison to QNX4) may be the reason
Could the difference be in the sender? These errors will be affected by the spacing between characters.
Thanks for the information.
Difference between your and mine devc-ser8250 is probably caused by the different release. I was using experimental
release of 6.5.0. from 23.6.2010.
I have also noticed the variation caused by sender.
I have DELL GX620 computer running windows XP, this computer is used as a sender. When I connect serial cable to real
serial port, it logs different errors on receiver's side to the situation when I connect serial cable to prolific
usb2serial port.
Thanks for your assistance.
Regards, PKY
