Forum Topic - Allocating physically contiguous memory below/above/across 4 GB boundary: (9 Items)
Hi All
x86 archi, I am playing around with some memory blocks being excahnged between processes (and hardware DMA-capable).
I always used mmap64() with (MAP_PHYS | MAP_ANON | MAP_NOINIT) flags for asking some physically contiguous memory, but
now I'm running on a machine with more than 4 GB of RAM, and I want to exploit all the available memory, launching
processes with "on -P".
Is there a way to control mmap64() for forcing allocation below 4GB? Processes where 32-bit DMA hardware is managed need
 it.
And conversely,  it there a way for leaving the kernel free to look for available phys memory also above (or crossing) 4
 GB ?
Thanks in advance.
Davide
Re: Allocating physically contiguous memory below/above/across 4 GB boundary
You will first need to update your boot image by adding option -x to
startup-bios in the build file to enable extended addressing.
Sure, I know...
I am able to use the memory over 4 GB for "normal" processes, but I am wondering how to manage the 32-bits addressing
issue when playing with physically contiguous blocks.
Davide
use function call like this:
posix_typed_mem_open("sysram&below4G", ...)
Thanks Jerry and all, your answers are really useful.
A last curiosity: what about the SPAWN_PADDR64_SAFE flag (on -P) ?
A call to mmap64(MAP_PHYS|MAP_ANON) or posix_typed_mem_open("sysram") from a process flagged SPAWN_PADDR64_SAFE will *
always* return contiguous RAM below 4 GB ?
Davide
RE: Allocating physically contiguous memory below/above/across 4 GB boundary
No, it is on the opposite side. If a process is flagged
SPAWN_PADDR64_SAFE, the kernel always try to allocate memory beyond 4G
first. Because if the process has SPAWN_PADDR64_SAFE flags, the kernel
assumes the process can handle physical memory beyound 4G.
Jerry
From: Davide Ancri [mailto:community-noreply@qnx.com]
Sent: December 28, 2010 4:09 AM
To: ostech-core_os
Subject: Re: Allocating physically contiguous memory below/above/across
4 GB boundary
from a process flagged SPAWN_PADDR64_SAFE will *always* return
Davide
OSTech
http://community.qnx.com/sf/go/post80509
Have you considered using the MAP_BELOW flag?
MAP_BELOW is not for physical memory, it is for virtual memory. It is used to map the stack address.
Yes you are right - and using the typed memory route which enforces the below4G requirement makes this a future-proofed
solution - before today I did not know this.
Thanks!
