Forum Topic - mkifs "cannot fork": (3 Items)
mkifs "cannot fork"
The release not for 6.3.2 mentions:
iff you're in a directory on a remote machine, and you pipe the output of a command to xargs, and you redirect the
output to a file, you get a “cannot fork” error. For example:
cd /net/remote_machine/tmp
find . -type f | xargs grep FAIL > report.txt
/bin/sh: cannot fork - try again
It seems to be a problem with permissions. Piping the output of xargs to less works. (Ref# 29834)
I have the same problem when using mkifs:
cd /net/...
mkifs qnxbasesmp.build >whatever
I get:
Unable to link relocatable elf file /usr/qnx630/target/qnx6/x86/boot/sys/startup-bios
Re: mkifs "cannot fork"
Yup, it's the same problem: spawning/forking with a fd's open to a mixture
of machines is screwing up somewhere.
	Brian
a command to xargs, and you redirect the output to a file, you get a
???cannot fork??? error. For example:
> cd /net/...
> I get:
> http://community.qnx.com/sf/go/post4202
I've added this to the release notes as a more general description of the problem. Thanks.
Steve Reid (stever@qnx.com)
Technical Editor
